http://echo1usa.com/English/images/SD-KIT_01.jpg
is it even possible to achieve the "SD" look on an m4 like this.....butttttt with a MOE handguard?
just let me know what you guys think
is it possible?
thebutnugget
is it possible?
Re: is it possible?
If you mean the suppressor running inside the handguard, probably not. But, if you get the right outer-barrel, you can have the hanguards with an RIS gasblock for a flip-up sight and a suppressor right after it. Magpul MOE handguards need a handguard ring at the front to hold them together, unlike a 1-piece RIS that's on the gun in your picture.
Re: is it possible?
You could make it so the barrel threads start right as the hand guard ends. That way your mock suppressor could hold the hand guard ring on instead of a gas block. That's about as close as you could get.
Team United Front CO
Vet:
OP24-Two________________OP Blackout
OP Phantom Hawk_________OP Anaconda
TDC (Ga/SC#1)___________OP Just Cause
OP Irene IX TFR 3-1___OP Ranch Hand-Vietcong CO
_____________________OP SoCo (Ga/SC#2)
Carpe noctem
Proprium nocte
unitedfrontairsoft.com
Vet:
Carpe noctem
Proprium nocte
