Situation:
My squad and and I are looking at a plate carrier that we want as a team. We wanted to get it in coyote brown so that it was possible to wear one load out for across factions, but the vest only comes in tan while all other gear doesn't. Multicam is an option, but we don't know if you can wear it over, say M81's, for games like SC vs Georgia when SC is Alpha.
Basically, can we wear multicam gear over M81s (looks aside)?
If we can't way may just have to get 2 separate loadouts all together.
Small Gear Delima
- Akaishinobi
Small Gear Delima
Akaishinobi a.k.a. Smoke
Re: Small Gear Delima
Call me crazy, but EVERYTHING comes in coyote. You can wear whatever gear you want as long as your top matches your faction colors.
- Akaishinobi
I thought so too man, but this no coyote brown this time. But thanks. That's perfect.
I feel like your gear-fu must be lacking in some regard. What can't you find in CB that is offered in MC?
Akaishinobi wrote:Basically, can we wear multicam gear over M81s (looks aside)?
Dominum wrote:Article III; Game Rules:
*The following game rules apply to all AOSC games unless otherwise noted.
Rule #8: Games have two teams: Alpha and Bravo, the teams are divided by the dominant color of their outfit:
Alpha is predominantly green uniforms such as: M81 BDU's, Woodland MarPat, Flecktarn ,etc.
Bravo is predominantly tan uniforms such as: Desert MarPat, MultiCam, DCUs, DBDUs, etc.
Balance colors will go to whichever side needs numbers: Black BDUs, Private Military Contractor, ACU, Urban Digi, civilian, etc., though they are usually considered Bravo.
A Game Director will balance factions depending on circumstances prior to game start.
Rule #9: Your gear's predominant color must match your outfit's predominant color UNLESS you have headgear of some form and sleeves that go at least to your elbows that are the same as your outfits predominant color . If you do not meet these requirements and your gear has a different predominant color than your outfit, you will be required to strip your gear. Weapon colors and paintjobs have no bearing on faction affiliation.
If you choose to wear headgear, it must match the predominant color of your uniform and/or you factions color schemes. This means that you may not wear green headgear with a tan uniform, and vice versa. If your headgear is a balancer camo (ACU for example), you may only wear it if ACU has been assigned to your faction, i.e. if ACU has been assigned to Alpha as a balancer at a particular game, than someone on Bravo may not wear ACU headgear. Additionally, red/orange headgear or any headgear easily mistaken for a deadrag may not be worn except as an actual deadrag.
ibeezthecapn
AEA airsofter, Anywhere Everywhere Anytime
Last Game OP Vietnam Patrol - US CO - Win
THANK YOU!!
THANK YOU!!
