Big Bertha Version 2.0
I've had plenty of questions about Big Bertha V2 since I redesigned my original, and I promised that eventually I would do some actual field tests under controlled circumstances. Well, after many months, I have.
I went to a friends property the other day and fired from a fixed position at measured angles of fire using a folding chair as my rest. All rounds were fired at 100PSI (+/-5) under the propolsion of a tire pump. Though I can run her off of any compressed air source that is schrader compatible, and usually use 12g CO2 cartridges for faster reload times, since I was testing and in no hurry I went with the $0 per round manual pump instead. The AoF was measured with a simple protractor and homemade plumb line, the PSI was measured by the gauge on the pump, and the distance of impact and landing were measured with a roll up tape measure. There was a ~3-5 MPH breeze that afternoon for which I had to make minor compensation. The lateral direction (aiming left or right) was simply eyeballed.
At a 50o AoF the range was exactly 400ft. This angle seems to be about the best range at that PSI. I fired 6 rnds in 3 minutes at this angle and pressure at a fixed target (2sqft) 400ft away to test the groupings. All 6 rnds landed within 25ft of the target, had it been a small building all but two of the rnds would have hit.
*pics coming...
*pics coming...
- ATAT Armorer
Re: Big Bertha Version 2.0
I would like to see how you built this. I might have to make one to fit in my Jeep.
Hit me up at a game and I will give you an overview, or I can build you one for $60.
I almost forgot, her longest clocked hangtime is a little over 9 seconds
- IronChef
PICS
I have to go home now, but I will dig some up from previous games when I get a minute this week.
I thought maybe this was relivant to the golf club series. </3
[img width=379 height=150]http://i241.photobucket.com/albums/ff20 ... 7Tac-1.jpg[/img]
- ATAT Armorer
I will be at Op.24. A few of these in fixed positions at the blue hole would make for some interesting game mechanics.
- Trig
- Here for a while...
Just a quick check pneumatics are the only allowed cannons of any sorts, right?
Wesley: "I think I just heard Luke yelling."
Me: "...That was a goat."
Yes.
not the best pic but anyways...
[img width=700 height=524]http://i771.photobucket.com/albums/xx35 ... 24/071.jpg[/img]
Quote of The Day
OP White Noise vet.
OP24 vet. & victorious team staff medic
Silent Sniper of The Hill
OP Desert Locust vet.Inked wrote: A Fact of Life: After Monday and Tuesday even the calendar says W T F.....
OP White Noise vet.
Was this when we tested it at RedFox. I remember it having a ridiculous amount of hangtime.Dominum wrote: I almost forgot, her longest clocked hangtime is a little over 9 seconds.
Either there or at Saluda. Either way, it is quite an effective launcher, albeit not the prettiest one on the block.
Yeah, hangtime is 9 seconds, we usually do that at every Redfox game just for gits and shiggles. Someday I'd like to make an historically accurate version that actually resembles a real weapon, but until then I'm going for effectiveness, durability, and low cost. No need for anything fancy seeing as there's only good reason to field it about twice a year.
