Tokyo Marui SPAS-12 spring shotgun
Head this way for reviews of spring-operated airsoft guns.
FightTheEnemy
Post by FightTheEnemy » Sun May 16, 2010 11:45 pm
 Tokyo Marui SPAS 12
well I finally got one, and I must say that I am very impressed. I ordered it along with three extra shells from trinity airsoft for a grand total of $210
[img width=700 height=524]http://i122.photobucket.com/albums/o254 ... C01322.jpg[/img]
It is constructed of abs plastic with plenty of metal parts such as the barrel, sights, trigger, bolt, etc. Its unique design allows it to fires three bbs simultaneously from three barrels. One hop-up dial adjusts all three barrels at once.It fires around 300 feet per second with .2s.
[img width=700 height=524]http://i122.photobucket.com/albums/o254 ... C01330.jpg[/img]
This shotgun uses 30 round shells. since this weapon fires 3 bbs per pump, that means that there are 10 pumps per shell
[img width=700 height=524]http://i122.photobucket.com/albums/o254 ... C01324.jpg[/img]
[img width=700 height=524]http://i122.photobucket.com/albums/o254 ... C01325.jpg[/img]
once the shell is loaded, you depress a lever located in front of the trigger guard to open the hatch for the shell
[img width=700 height=524]http://i122.photobucket.com/albums/o254 ... C01326.jpg[/img]
insert the shell into the chamber:
[img width=700 height=524]http://i122.photobucket.com/albums/o254 ... C01327.jpg[/img]
and then close the hatch:
[img width=700 height=524]http://i122.photobucket.com/albums/o254 ... C01328.jpg[/img]
and then your done!
Final Conclusion
looks 10/10-do I need to explain this one?
reliability 10/10-this thing will never let you down. It does not use a battery or gas so weather does not affect it. This is a good back up gun when your AEG malfunctions.
compared to an aeg 6/10-this may have the same range of an aeg but certainly not the firepower. It has a nice spread which increases with distance just like a real shotgun but you could just use a rifle on full auto. If you choose this gun, then you definitely need to be the tactical sort. Great for CQB also.
If you have any other questions then feel free to ask.
I taste how that would feel
