PAYMENT PREFERENCE(S):Paypal or cash
ITEM(S):KWA sr12 and sr7 custom
PRICE(S)neg...
DESCRIPTION(S):
For sale is a Custom KWA SR12 DMR. I built this gun as a long range rifle that had the capabilities to defend myself in a fire fight. The externals include: Madbull Patriot sniper front end, the outer barrel was originally chrome but I had it turned black for night games. Next I added a JG right handed SPR grip and a nice 3X9 scope w/bullet drop. The rest of the externals are stock KWA.
The internals were designed to give a more consistent velocity on semi. They consist of a SHS 15 steel tooth piston, SHS double O-ring cylinder head, Systema type-0 cylinder, Guarder ported aluminum piston head, Guarded m130 spring, Madbull 6.03mm tight bore. The rest of the internals are stock KWA since most of KWA's parts are high torque anyways. It's wired to deans and shoots 430fps w/.25's and around 23-25rps on full auto.
I am including 2 KWA hi-caps, 1 jg stubby high cap, a 9.6v 5000mah battery that lasts forever and can power this spring with ease. I am also including a Tenergy smart charger.
For sale is my custom built KWA SR7 styled after the PWS Diablo. I built this gun as a unique AR platform that had an extreme rate of fire but still preformed reliably. The gun started out as a stock SR7 but the externals have been completely changed. Installed are: Magpul MOE trigger guard, pistol grip, Magpul 7in. rail covers, as well as magpuls on both KWA hi-caps included. Next comes Madbull's parts: The PWS Diablo front ris and outer barrel, ACE stubby stock, qd sling swivel, G5 quick detach surpressor, shark charging handle and KWA quick detach iron sights.
Internally this gun was built for speed, starting with SHS 13:1 gears, a SHS 14 tooth ported piston, Guarder ported polycarb piston head, Guarder m100 spring, G&P m120 high speed motor w/ G&P wiring to deans in the buffer tube. Lastly the internals feature a madbull 6.03 tightbore and the rest is stock KWA.
This gun shoots 330fps with .2's and around 35-38 rps on a buffer tube li-po. Included are 2 kwa hi-caps, 1 point bungee sling, original factory KWA gears in perfect shape, and extra shims in order to tune the gun to your liking. I have it shimmed perfectly for semi-auto and those quick little bursts.
Lastly is my full metal G&P gbbr M4 with a vltor casv handguard and a Troy flip up rear sight. It comes with 2 metal ghk c02 mags that both work though one is missing the cap for the co2. The gun is in good shape over all but it needs a new hop-up-$25, bolt catch detent spring-$5 and a selector switch spring and detent-$5. These parts prices are based on evike. The gun does shoot so I'm asking $150 obo please make an offer.
I am asking $300 for each kwa or $550 if you buy both my prices are VERY negotiable because I desperately need money so please feel free to make an offer, no reasonable offer turned away. More pics are coming tonight. Thanks
