Getting rid of everything. Please, take it all. Low prices.
List your airsoft items for sale/trade here.
Muff-in
I like this place!
I like this place!
Post by Muff-in » Mon Oct 29, 2012 10:02 pm
Sorry for the large pictures, I'm not sure how to resize images.
More to come in the next couple of days, don't have time to do this all at once. Stay tuned.
Here is the link to the album of pics of the stuff I have taken pics of so far. Take a look. I will list everything out soon. http://imgur.com/a/N0IPU
Ok, I no longer have time for airsoft anymore. I need to get rid of everything ASAP, so I'm going to say this now. I will not be parting this out. I may do groups of items at a time, but preferably everything at once. I will give an extremely good deal to whoever takes it all. And I also have tons of other crap laying around that's not pictured that I will throw in as well.
I am asking $650 for everything!! I may be willing to negotiate. Also would be willing to do trade, trade + cash. Looking for real AR-15 parts, computers, tablets, iPods, gym equipment, guitars, car parts, or anything else really. Hit me up with what you got.
Ok, I will list these all in groups. I don't have the time to take a pic of everything individually.
Pictured below:
KWA SR12:
Internals (from barrel to stock):
Madbull black python 509mm 6.03 mm barrel
stock hop up unit
Mediocre attempt at an R-Hop. It shoots far, but the bullets kinda move left/right slightly. It could just need cleaning, but I just don't have the time to fix it. Also has an M-Nub
Stock nozzle
Stock cylinder head with 1/4" 70D sorbo
Lonex POM ball bearing piston head
SHS 15 Metal tooth piston with 2 1/4 teeth removed to fix the AoE
~M115 spring
Stock gears/bushings (gears have NO shims on them. They were PERFECT OOTB)
Stock Spring Guide w/bearings
Stock Cylinder with the port on it covered.
Matrix High Torque Motor
Everything rewired to deans
Stock Trigger contacts
Stock AR latch/ COL
Externals:
Magpul AFG (Real Deal, not ACM clone)
Magpul MBUS (Clones)
Magpul MOE pistol grip
Larue Tactical Mount (real steel Aimpoint mount)
G&P Aimpoint, Red/Green dot -needs batteries soon
Realsteel foregrip, used to attach pressure switch for tactical light.
Powertac E5:
This flashlight is utterly amazing. 700 Lumens!!! This will give you a huge advantage out on the field (indoors anyways). It has strobe mode as well.
Comes with 6 CR123A batteries.
Also it comes with the weapon mount kit - has pressure switch and rings to attach to RIS. Also comes with extra hardware.
Other
Batteries: (All work perfectly, should have PLENTY of life left)
3300MAH 9.6v (In the stock of the gun)
1200MAH 9.6v (Purple one)
2200MAH 9.6v (black one)
Smart Charger w/ deans
6 green label PMAGs, feed perfectly in this gun. Most of them are jammed due to my buddy overloading them. This is a common problem and can easily be fixed, but like I said, I don't have the time.
Some other random Hi-Caps/Midcaps - all working. Not guarenteed to feed perfectly, due to the high ROF. I know the midcaps feed great, but not sure about the hi's.
Noveske Sound amplifying flash hider 14mm-
-Brand new pretty much, no scratches
Re: Getting rid of everything. Please, take it all. Low pric
Post by Dominum » Tue Oct 30, 2012 5:57 pm
What about a dirt bike as a trade?
Muff-in
I like this place!
I like this place!
Post by Muff-in » Mon Nov 12, 2012 11:24 pm
Lol no thanks man. If i had the land for one maybe
