A&K M16 SPR
List your airsoft items for sale/trade here.
Schmarvin
A&K M16 SPR
Post by Schmarvin » Sun Dec 02, 2012 1:47 pm
LOCATION(S): Ladson/Summerville, SC
PAYMENT PREFERENCE(S): Cash, Paypal
ITEM(S): A&K M16 SPR
PRICE(S): $180 OBO
DESCRIPTION(S): Looking to get rid of this gun. It still shoots fine and has some distance. But, I need a bit longer range from a gun. I believe its a 6.04mm inner barrel. I have also upgraded the hopup to the Madbull Hopup Unit (with the option to install an led tracer unit). Everything else is stock, other than having a missing cap for the back crane stock to hold the nunchuck battery in. Normally gun sells for $199 via Evike brand new
Only a little bit of wear and tear on the gun from when I had it slinged. It does come with a rail-mounted sling clip. Gun also includes and 8.4v Nunchuck/Butterfly battery and yes, the battery still works. Will even throw in a free wall charger.
It shoots anywhere from 330 to 410 fps. Depending on the battery.
PICTURE(S):
PART OUT?: No.
ACCEPT/OFFER TRADE(S)?: No.
Any other questions, feel free to ask.
Team Extorrus, XO
OP 24-3
Germany II
The Swamp Opening
SQA Springtime Airsoft
OP: Second Sun
OP Apple Pie
Blue Hole 7/7/12
Blue Hole 9/15/12
Blue Hole 12/1/12
A&K M16 Mod 0 SPR w/ 3 Hi-cap (1 450rd/1 500rd) and 4 mid-cap (110rd)
KJW M1911
Schmarvin
Re: A&K M16 SPR
Post by Schmarvin » Tue Dec 04, 2012 8:48 pm
Team Extorrus, XO
OP 24-3
Germany II
The Swamp Opening
OP: Second Sun
OP Apple Pie
Blue Hole 7/7/12
Blue Hole 9/15/12
Blue Hole 12/1/12
KJW M1911
Re: A&K M16 SPR
Post by Dominum » Tue Dec 04, 2012 9:32 pm
Schmarvin wrote:It shoots anywhere from 330 to 410 fps. Depending on the battery.
Did you mean to say "BB weight" instead of "Battery"? If not, I suggest you do a little bit of reading, and then correct your OP.
Schmarvin
Re: A&K M16 SPR
Post by Schmarvin » Wed Dec 05, 2012 9:15 am
No, it literally can vary from 310 to 410 fps. Even on the same battery. It may be the gearbox as I had issues with it in the past and it has somehow fixed itself.
Team Extorrus, XO
OP 24-3
Germany II
The Swamp Opening
OP: Second Sun
OP Apple Pie
Blue Hole 7/7/12
Blue Hole 9/15/12
Blue Hole 12/1/12
KJW M1911
Re: A&K M16 SPR
Post by SteevoLS » Wed Dec 05, 2012 2:08 pm
Then your air nozzle/cylinder/piston head is cracked or leaking.
Schmarvin
Re: A&K M16 SPR
Post by Schmarvin » Wed Dec 05, 2012 6:12 pm
SteevoLS wrote:Then your air nozzle/cylinder/piston head is cracked or leaking.
Might be leaking, if I'm not mistaken, A&K use cheaper quality air nozzles.
Team Extorrus, XO
OP 24-3
Germany II
The Swamp Opening
OP: Second Sun
OP Apple Pie
Blue Hole 7/7/12
Blue Hole 9/15/12
Blue Hole 12/1/12
KJW M1911
Schmarvin
Re: A&K M16 SPR
Post by Schmarvin » Sun Dec 16, 2012 4:03 pm
~Sold~
Team Extorrus, XO
OP 24-3
Germany II
The Swamp Opening
OP: Second Sun
OP Apple Pie
Blue Hole 7/7/12
Blue Hole 9/15/12
Blue Hole 12/1/12
KJW M1911
