Here is a picture of everything. All the wiring at the top right is NOT included.
From left to right, I'll name everything I can. I am not looking to part this out, sorry.
3 VFGs, nothing fancy
KWA 2GX gearbox, nothing included. Motor grip threads are stripped.
M4 Iron sights, charging handle, and 3 buffer tube spacers (bottome left one is sold), and various body pins, mag releases, trigger guards, selector switches, bolt releases.
3 pistons w/ piston head. Left one is stock Dboys, Middle is from a G&G w/ a Super Shooter aluminum head, and right is stock G&P, swiss cheesed. I've never actually used it, so teeth are brand new.
Thunder B trip wire, and spare pin
Assortment of springs. Bottom two are the only ones I'm sure of. The silver one is a SHS M150 and the above that is a Matrix M130.
Stock cylinders
Stock Spring guides,
Bunch of ARLs, with springs
4 triggers with springs
3 Tappet plates, w/ springs
6 cylinder heads, the red one is a SHS (the two holes I bored out a bit larger so they actually fit in the gearbox)
Various nozzles, the two red ones are SHS (one sold) and the black one is a KWA
Some COLs with screws
Safety assembly
Two selector plates. One is SHS.
Gearbox shell, Dboys I believe. 6MM. Inside the gearbox is a tappet plate, full cylinder, COL, and safety assemebly. The bearings are included.
Stock metal hop up. No nub is included.
I will give more info on gears later. I have to take em out and look at em again. I know there are two sets of JG gears, full set of new G&P gears, SHS bevel and sector.
3 G&P M120s, pinions with minimal wear.
As I said, if I can't get $50 TODAY (3/22) I will try and sell this for more, and possibly part out. I am in the Gvill area.
