Item: G&G FN 2000 parts gun comes w/ gun body, hop up unit barrel, gearbox shell, piston, piston head, cylinder head, tappet plate arl, No motor, bushings. When originally purchased went to upgrade it and had problems with the firing selector, the gun would either work in semi only or only fire in burst.
PRICE: 100$ photo. Trades welcomed.
Description:When originally purchased went to upgrade it and had problems with the firing selector, the gun would either work in semi only or only fire in burst. To make whole again a motor will be needed, gearbox bushings, maybe a few misc. gearbox parts, and fix the firing mechanism and selector issue. Great for techs w/ experience w/ these guns.
PICTURES:
part out: NO, want to sell the whole package.
Trades: Absolutely, basic aeg such as m4, ak 47, numerous m4 mags, lipos, pistols, mosfets, essentially any gear I could use.
FN 2000 parts gun (broken was semi functioning)
|VFC M4 "Dirty Harry"|
Re: FN 2000 parts gun (broken was semi functioning)
bump, updated found piston, gears, piston head, cylinder head etc.
so what all does that leave?
bushings, some small springs and screws (i have some of them) and a motor, then you just have to address the firing issue which from my reading is something to do w/ the selector switch mech and possibly the trigger mech. Also probably should be re wired.
