PAYMENT PREFERENCE(S): Cash, but willing to consider others.
*All guns wired to Deans connectors. Each will come with one appropriately sized LiPo battery*
ITEM(S): Tan Magpul Masada ($400 w/ magazine)
This Masada has been used lightly with approximately 10-15 games in use. The fire selector has been painted white and red to the corresponding selection. The only damage is under the handguard a small hole was drilled in order to mount a rail in a specific location in order to closely mount an EGLM. I also still have the original packaging for this. Price is negotiable.
KWA KMP9 ($190 w/ magazine)
Lightly used KMP9 that has been to maybe 5 games in total. Currently has the Danger Werx low flow valve installed to meet CQB regulations but comes with the standard valve also. Has no damage to the SMG. I also have the original packaging. Will include propane adapter for $10. Also willing to negotiate on price.
Built from the Ground Daniel Defense DMR ($550) Price is negotiable
I started this as a project but eventually lost interest in playing because all off my friends quit. She made it out to only one full game and preformed much better than I anticipated. I poured more money than I should have and she hasn't gotten enough love. The only thing that needs to be done is the M150 spring installed and a new shim job. Other than that she is ready to rock and roll.
Parts List:
Extreme Fire Cheetah 2N MOSFET $122
Lonex A2 Infinite Torque Up Motor $49
Modify Torus Reinforced Gearbox $50
Guarder Red Piston Head $12
Madbull Dragon Fire 16.25” Rai System $68
Madbull Daniel Defense 20” Barrel $52
Madbull Vickers Upper and Lower $113
Systema M150 spring $15
G&P Reciever Parts $10
Madbull Aluminum 509mm 6.01 TBB $45
Guarder Air Nozzle $12
CNC Cylinder head w/ Double O-Rings $16
APS Chrome Full Cylinder
Lonex Red Piston $20
SHS Steel Gears 18:1 $22
ZCI Ball Bearing Spring Guide $5
Sorbo Pads/Protector $7
G&P Full/Adjustable Stock $80
Total: $638
VFC Tan EGLM ($120)
Lightly used EGLM that comes with a G&P “Long Range” 18rnd grenade shell and 12 Evike foam balls. Still have original packaging. Will include propane adapter for $10.
Condor Plate Carrier ($80)
This carrier comes with a hydration carrier, a 2x3 STANAG Magazine pouch, a 2x2 STANAG Magazine pouch, Phantom Dump Pouch, Grenade Pouch, Admin Pouch, and a Utility Pouch.
Revision Locust Goggles ($45)
Used Revisions that are in good condition. These come with smoke lenses but I also have some clear ones for sale. The foam around the edges has been taken off to reduce fogging.
Revision Locust Clear Lenses ($15)
Clear lenses that were used only a handful of times. And that is not a crack in the lens, it’s the box underneath it.
Mid Cap Magazines ($10 per magazine)
Hi Cap Magazines ~330rnds ($20)
G&G 450rnd Hi Cap Magazine ($30)
KWA KMP9 Magazines ($35 per Magazine)
Perfect condition KWA magazines that saw little usage.
LiPo Batteries
11.1v 3300mAh LiPo is for the DMR
7.4v 1800mAh LiPo ($15)
One 7.4v 1300 mAh LiPo is for the Masada
7.4v 1300 mAh LiPo ($10)
LiPo Bag ($10)
Thunder AC6 Battery Charger ($40) SOLD
Charges practically all batteries. LiPo, NiCd, NiMh an Pb batteries. It has so many different features that I can’t even remember, including a discharger.
PRICE(S) See Above. Will negotiate on any price.
COMMUNICATION:PM
DESCRIPTION(S): See above
PICTURE(S): See above
PART OUT?:Possibly, depends on item.
