Now, I'm not talking about a spray-painted gun. I'm talking about the original black paint that comes with the gun in order to expose the original silver color of metal.
I'm thinking about stripping the paint off of the buffer tube and the barrel.
Any help?
How to strip/chip paint off from the gun.
Re: How to strip/chip paint off from the gun.
they got this stuff called Stypeeze. not sure if its meant for the metal of the barrel, but its worth looking at.
Funny you should ask, I just started stripping the paint off my outer barrel yesterday.
Take a knife, and very carefully make a small scratch in the paint. Or, if the barrel is already scratched up, that works too. After that, take steel wool and work the paint off, starting at that scratch. That's how I've done mine, and it's worked fine.
Kill bodies and slay dragons.
I may just dremmel them.
- idiot88
Has anyone tried acetone or some other paint stripping chemical?
Help control the population. Spay and neuter your humans.
Go to NAPA/Autozone and look for Aircraft Paint Stripper. Used that stuff to remove the paint on my ZX-7 rims. Then polished them up. If that doesn't take it off, then sandblasting would be the best.
If you need to, I could let you use my sand blaster. Not an industrial one, It's just some tips/suction hose for my air compressor. Still have some sand too.
Haven't seen aircraft stripper in a while at my local napa, don't think they carry it anymore.
A Fact of Life: After Monday and Tuesday even the calendar says W T F.....
Severed: if the back up to the back up back up rifle doesn't make people drool, you = fail
Airsoft Vet.
Airsoft Vet.
