Changing barrel on a SCAR
boga
Post by boga » Tue Mar 16, 2010 9:01 pm
Anyone here who knows how to change the barrel on a SCAR. Mine came with a standard barrel I just want to know how to replace it. Thanks...
Re: Changing barrel on a SCAR
Post by SteevoLS » Tue Mar 16, 2010 9:20 pm
Are you trying to replace the outer (cosmetic) barrel, or the inner barrel that the BB actually passes through?
boga
Post by boga » Tue Mar 16, 2010 9:36 pm
hey stevo, yup its the cosmetic. the stock is a cqc barrel and it also came with standard b. how do i change it without damaging my gun
Post by SteevoLS » Tue Mar 16, 2010 9:46 pm
I don't know what make your SCAR is, but on most of the chiclone's the longer barrel is just a glorified flashhider. You can screw it on and off.
What brand is your SCAR?
boga
Post by boga » Tue Mar 16, 2010 10:05 pm
its an agm
MCG
Post by MCG » Tue Mar 16, 2010 10:07 pm
boga wrote: its an agm
In that case, all you need to do is screw off the outer barrel at the seam. I don't believe it is glued, but it may be, in which case you'll have to hold it under a hair-dryer for a few minutes.
Kill bodies and slay dragons.
Post by SteevoLS » Tue Mar 16, 2010 10:13 pm
Post by Dominum » Wed Mar 17, 2010 10:16 am
I'll do it for you when you come by this afternoon Boga.
Vesper
Post by Vesper » Fri Mar 19, 2010 10:41 am
EVIKE.COM - Disassembly Guide for DBoy SCAR
This might help you out.
I do understand that your SCAR is manufactured by AGM, and this video features D-Boys SCAR, but most of these basic features should be identical.
