Changing JGMK36C Inner Barrel
Darth Chuckie
Post by Darth Chuckie » Thu Mar 18, 2010 7:46 pm
I want to put a tight bore barrel in my MK and found a site showing how to take out the outer barrel from the gun. I did this but was unable to figure out how to get the inner barrel out. Can someone help me and tell me how to get it out of the outer barrel.
Thanks
Rest in Peace, 4-4-14.
DBoys M4 RIS
DBoys SCAR
JG G36C
JG M16 UFC
1911 GBB
Re: Changing JGMK36C Inner Barrel
Post by Dominum » Thu Mar 18, 2010 7:49 pm
You do not have to remove the outer barrel to remove the inner barrel and hopup chamber. You have to remove the stock and then the lower receiver, then slide the hopup chamber and barrel out the back of the upper receiver/outer barrel.
Jeremy314
Post by Jeremy314 » Thu Mar 18, 2010 9:04 pm
Dom, you don't have to take off the stock on a G36.. just fold it. Unless you're taking about taking the hex bolt out of the back were the stock foldins.
Villid
Post by Villid » Thu Mar 18, 2010 10:47 pm
Removing the upper barrel assembly is probablly and easier way to do it, since you can remove it without taking out the gearbox or anything like that.  DO NOT PULL HTE INNER BARREL OUT BY FORCE!  This is an expensive ($25+shipping) mistake to make.  Believe me i know.  Push the inner barrel and hopup assembly, and turn it counter clockwise,  it should make a quarter turn and when you let off hte pressure, it should come right out.  good luck.
Post by Dominum » Tue Mar 23, 2010 6:34 pm
Jeremy314 wrote: Dom, you don't have to take off the stock on a G36.. just fold it. Unless you're taking about taking the hex bolt out of the back were the stock foldins.
Yeah, that's what I meant ;).
Darth Chuckie
Post by Darth Chuckie » Fri Mar 26, 2010 5:58 pm
Villid, looks like I found out your mistake the hard way. I pulled to hard and the hop up unit broke to pieces. Ordered one a little bit ago.
DBoys M4 RIS
DBoys SCAR
JG G36C
JG M16 UFC
1911 GBB
Villid
Post by Villid » Sat Mar 27, 2010 8:41 am
sounds like you did something differnt from me.  my hopup stayed intact, i broke the catches on the barrel assembly that hold the barrel and hopup in place.  either way the cost is about the same.  hope you took the time to order an upgraded bucking and nub since youve got it apart anyway
