Here's what I have in it now...
CA Helical Gears
CA Bore Up Kit ( compression is good )
G&G Extended Piston
CA Hop Up Unit
G&G Bucking
Stock nub
Madbull 6.03 TBB
Systema PSG1 200% Spring
MOSFET
It is shooting a consistent 400 fps w/ .20's with all of this. My target is a 2 joule DM platform. The 200% spring, according to different sites, should put it close to that.
I've tried using the following parts in different combinations Madbull hop up, Madbull blue bucking, M130 spring, Duracon piston head, new OEM air nozzle, original OEM cylinder, piston, piston head, air nozzle and cylinder head. The different combos of these parts have yielded between 330 - 365 fps.
Any thoughts on what else can be done to hit that target other than upping the spring higher?
