gun lube
Chippy
gun lube
Post by Chippy » Wed Jan 12, 2011 3:07 pm
Ok, so my echo1 m28 just arrived today and mmtge bolt on it is dry. I dont have any actual lube made for bolts but what other lubes can i use?
Is there a specific type? or can I use wd40 or a water based one?
Hawaii 5-0
Echo1 Scar-L
Cyma M14
TM MP7 AEP
TM AK74/105
Re: gun lube
Post by SteevoLS » Wed Jan 12, 2011 3:16 pm
Use silicone oil on the O-rings, a use either silicone oil or white lithium grease on the moving metal parts. NEVER use WD40 in any airsoft situation.
Chippy
Re: gun lube
Post by Chippy » Wed Jan 12, 2011 3:39 pm
Thank you for saving my rifle. I was in such hurry i was about to apply wd40 :o
And I'm awfully confused on your directions. I may have used the wrong wording before, but all I need to do is just lube up the outer bolt, as in the silver piece that is constantly visible . So what should I use there?
Hawaii 5-0
Echo1 Scar-L
Cyma M14
TM MP7 AEP
TM AK74/105
Re: gun lube
Post by SteevoLS » Wed Jan 12, 2011 3:43 pm
Silicone oil or white lithium should be fine. Bolties aren't my area of expertise, though, so it might not hurt to wait for somebody like Clutch to weigh in.
Chippy
Re: gun lube
Post by Chippy » Wed Jan 12, 2011 3:55 pm
Aight. Thanks for your help man
Hawaii 5-0
Echo1 Scar-L
Cyma M14
TM MP7 AEP
TM AK74/105
Smoke
Re: gun lube
Post by Smoke » Wed Jan 12, 2011 4:08 pm
If you know how to take it down into 2 parts i would do that and use some silicon oil and try to stay away from silicon grease on the outside of the cylinder because the thicker grease tends to attract alot of dirt. If you don't know how to break it down just put some silicon oil on the outside of the cylinder by pulling the bolt back like you a trying to load a bb and lightly coat it that way. If you have any questions about lubing inside the cylinder just let us know....
tm l96 aws
kwa sr-12
kwa sr-5
echo 1 asr
de m81
kwa g17
Chippy
Re: gun lube
Post by Chippy » Wed Jan 12, 2011 4:13 pm
Thanks smoke!
Now I just have to get some silicon oil.
I don't think it will need to be lubed on the inside, just the outside.
Hawaii 5-0
Echo1 Scar-L
Cyma M14
TM MP7 AEP
TM AK74/105
Smoke
Re: gun lube
Post by Smoke » Wed Jan 12, 2011 4:35 pm
Chippy wrote: Thanks smoke!
You never know till ya open it up...My echo 1 needed to be cleaned and lubed inside and out ...but...I'm kinda picky too.....
tm l96 aws
kwa sr-12
kwa sr-5
echo 1 asr
de m81
kwa g17
Chippy
Re: gun lube
Post by Chippy » Wed Jan 12, 2011 4:43 pm
Ehh, I might as well. I just need to find a take down video...or hand it over to one of you guys to do :p
Hawaii 5-0
Echo1 Scar-L
Cyma M14
TM MP7 AEP
TM AK74/105
Re: gun lube
Post by Dominum » Wed Jan 12, 2011 7:16 pm
^Ditto to Smoke on both counts, Chiclones usually come with crappy lube and compression.
Chippy
Re: gun lube
Post by Chippy » Thu Jan 13, 2011 3:45 pm
Ok, so I just found sme winchester gun lube/cleaner in my storage room. Its called 'winchester break free CLP cleaner/lubricant/preservative'
Its made from petroleum distillates.
It says to:
- apply to metal surfaces
- Allow a few minutes ir more for penetration and cleaning action to occur.
-with movement or brushing of the parts foreign matter will break loose and can be wiped away.
-break free clp lubricates immediately.
So will this work?
Hawaii 5-0
Echo1 Scar-L
Cyma M14
TM MP7 AEP
TM AK74/105
Re: gun lube
Post by SteevoLS » Thu Jan 13, 2011 4:04 pm
NO! Never, ever use anything intended for real firearms on airsoft guns unless it is silicone based. That will chew through your O-rings like [racist chicken joke here].
Chippy
Re: gun lube
Post by Chippy » Thu Jan 13, 2011 4:08 pm
So not even on the outer bolt? Ok, so can I just use the lube that comes with propane adapters/GBB? I'm pretty that stuff is silicon based.
Hawaii 5-0
Echo1 Scar-L
Cyma M14
TM MP7 AEP
TM AK74/105
PRincess
Re: gun lube
Post by PRincess » Thu Jan 13, 2011 4:10 pm
Chippy wrote: So not even on the outer bolt? Ok, so can I just use the lube that comes with propane adapters/GBB? I'm pretty that stuff is silicon based.
Yes... You can use that as it is 100% Silicon Oil...
Pew pew pew... 'Murica
Chippy
Re: gun lube
Post by Chippy » Thu Jan 13, 2011 4:14 pm
Aight. Thanks guys, now I just have to go search around my room for it.
Hawaii 5-0
Echo1 Scar-L
Cyma M14
TM MP7 AEP
TM AK74/105
