Okay so here's the deal:
Just got this Echo1 P90(used) a few weeks ago and the semi-auto would not work properly --- it would take a few pulls to get a shot out --- so I sprayed some contact cleaner on the contacts and it worked good for about a mid-cap worth of shots and now it wont fire on semi at all. Any ideas as to what's going down?
Echo1 P90 semi-auto issue
Re: Echo1 P90 semi-auto issue
Check the cutoff lever for wear, and make sure the metal bars that connect the actual trigger to the gearbox are in place properly.
Unfortunately this is a very common problem for most P90 models that sometimes can't be resolved due to the low tolerances at which the Chiclone models' parts are manufactured.
Tzer1993
Translation: Buy better parts. GotchaDominum wrote: Check the cutoff lever for wear, and make sure the metal bars that connect the actual trigger to the gearbox are in place properly.
I'll see what I can do...
Tzer1993
Well I got it working...for the time being
I just had to carve the black gunk of the contacts with a razor...
MetalWarrior
Yea, if there is wear on the cutoff lever, I would suggest getting a new one considering that I have had the same problem.
MW now has perfect three round burst if he pulls the trigger right on semi
