g&g problems
st3althyst0rm
g&g problems
Post by st3althyst0rm » Fri Mar 18, 2011 9:29 pm
recently(ish) bought a g&g raider, it is not the blowback model. i am having problems with the firing of the gun. i will take it apart, gearbox and all, look for problems, see none, put it back together, and get 20 to 30 shots out of it before it does not shoot. i think it is something electrical because i don't hear the motor spinning. a while back i did fire it a lot during a game and i might have overheated the motor. i have checked all the connections, and the trigger box and all the solders and connections look fine. is the motor bad? if not what is wrong?
Re: g&g problems
Post by Star_folder » Fri Mar 18, 2011 9:40 pm
Are you sure the battery is ok? That could be your problem.
If you have, then it is very possible the motor is dead. G&G doesn't always have the best motors in their guns.
st3althyst0rm
Re: g&g problems
Post by st3althyst0rm » Fri Mar 18, 2011 10:23 pm
iv tried 3 different batteries with it, two slightly used and one brand new, and still nothing any better.  what kind of motor do you suggest?
Re: g&g problems
Post by Star_folder » Fri Mar 18, 2011 10:51 pm
Well, an M130 deserves a good torque motor. Any "clone" torque motor will do just fine, by clone, I mean any of the cheap asian motors. JG motors are very strong, but you won't have a good rate of fire with them.
If you have the money though, I'd get a G&P M170 Motor. By far the best motor I have ever worked with. You'll get an outstanding rate of fire with that motor.
Re: g&g problems
Post by SteevoLS » Sat Mar 19, 2011 9:08 am
Don't order a motor before you're sure that's the problem; you might just be wasting money.
I haven't seen a late model G&G Raider; do they have auto-resetting fuses?
st3althyst0rm
Re: g&g problems
Post by st3althyst0rm » Sat Mar 19, 2011 11:49 am
yea, i don't want to pay for a motor then find out it still doesn't work. and it actually doesn't have a fuse, i was surprised. so i'm planning on putting one in. but i'm pretty sure its something electrical, and i don't know what else it could be besides the motor.
Re: g&g problems
Post by Dominum » Sat Mar 19, 2011 12:02 pm
Are the connectors small tamiyas? I have seen this sort of thing turn out to be loose ones before.
st3althyst0rm
Re: g&g problems
Post by st3althyst0rm » Sat Mar 19, 2011 12:08 pm
yes, the connector is a small tamiya, i actually had my charger plug slip out once and i couldn't figure out why it wasnt charging, haha. ok, i checked and the connections are fine in the tamiya plugs.
st3althyst0rm
Re: g&g problems
Post by st3althyst0rm » Sun Mar 20, 2011 6:45 pm
today i managed to squeeze about 50 rounds out of it before it stopped working, i out it down and about 30 seconds later i notice a weird smell, i immediately look at the battery and the tamiya connectors had melted together, so i quickly disconnected the wires and just let it sit. now i really have no clue what the problem is.
st3althyst0rm
Re: g&g problems
Post by st3althyst0rm » Mon Mar 21, 2011 5:22 pm
are the wires a too small gauge? what's wrong? if anyone can help please do so. i really need it.
Re: g&g problems
Post by Star_folder » Mon Mar 21, 2011 5:51 pm
What voltage is the battery you are using?
Re: g&g problems
Post by Dominum » Mon Mar 21, 2011 10:28 pm
Well, it is a G&G after all, so you can expect that to happen if you use a strong battery.
st3althyst0rm
Re: g&g problems
Post by st3althyst0rm » Wed Mar 23, 2011 9:53 am
i'm using a 9.6v 1600 mah, i don't really want to use anything higher because, after all, it is a g&g. i will be getting some deans connectors sometime soon to keep the connections from burning like tamiyas always do to me.
theboss62
Re: g&g problems
Post by theboss62 » Wed Mar 23, 2011 2:58 pm
Dominum wrote:Well, it is a G&G after all, so you can expect that to happen if you use a strong battery.
nothing wrong with G&G. their wiring yes
Re: g&g problems
Post by Dominum » Wed Mar 23, 2011 6:33 pm
Uhhh, that is exactly what I said Walker...
