CYMA cm041b disassembly guide
I just need a guide to the take down of the cm041b. I also need to know the specs of this gun because I find a diffrent answer everywhere I look. Gearbox type, inner barrel length, and stuff like that. THANKS!
Is tactical pastel pony
Re: CYMA cm041b disassembly guide
If it has a "realistic" takedown procedure, then remove the stock and body pin behind the magwell and the lower receiver (containing the gearbox) should pop right out. Full size MP5s generally have a 229mm/9" barrel and a V2 gearbox.
Like all MP5s (except Ks and K PDWs) it has a V2 gearbox. Unless they have changed it then it is the standard MP5 clamshell design. Look on Youtube for airsoft MP5 take down guides or find someone who has opened one before to help you.
