Okay so I have been trying to decide how to put an M249 box some way on L86. Now there is no good way to mOunt it because of the bullpup style weapon. Now I saw this
http://www.airsoftretreat.com/forums/in ... ic=66101.0
Could I run these longer springs maybe from an m249 pouch on my side? Or is this a foolish dream
Support weapon help
Support weapon help
Team AJAX
Arsenal- in the works
Re: Support weapon help
If you try to do it from a pouch on your side I foresee it not only getting caught or crimped on and between everything, but I don't think the mechanics of the mag exert enough pressure to push the massive amount of BBs that would be inside the feeding tube all at once. This is, however, merely speculation.
ya Blackout that would work fine... I am just looking for options that are in stock... Those will prolly never come in stock again
Team AJAX
Correct me if I'm wrong, but wouldn't any CMag work in that gun? The L85/L86 uses a standard M4 midcap or hicap, so unless the outside of the magwell is too big it should lock right in.
The magwell is a lot deeper than a normal M4
Team AJAX
you could use those double m4 mag things that are two like glued together but electric and holds 1000 rounds.
if you knew someone who was good at modifying things they could probably chop a standard c-mag and scab on a taller part from a m4 lowcap, so that it would fit in the deeper magwell. or chop the magwell a little if you didn't mind sacrificing a little bit of the body of the gun.
I've considered doing something like that to fit a C-mag underneath the EGLM grenade launcher on my scar, but I kinda figured it'd make the gun look terrible
