Poszible Tokyo Mauri M93 Raffica Upgrades
- Romba
Happy friday the 13th! I will be buying an M93 raffica from Robin (thanks Steevo for being courier) and I want to know what ups I can get. The thing will already come with
KSC Folding stock
Tightbore
Scope mount slide
RIS
So what else can I get? I would like a lipo for it (info on how to aquire one would be appreciated) and I kno I am going to want a couple high caps. But what else is there? Ill add more later. Typing this on dads smartphone on the way to PASS testing. Thanks in advance.
KSC Folding stock
Tightbore
Scope mount slide
RIS
Re: Poszible Tokyo Mauri M93 Raffica Upgrades
I can either build a lipo for you (unfortunately they are fragile and will only last if you always leave it in the gun), or you can buy one from Eagle6 in the UK for about $50. Don't touch anything else; it already shoots like a dream and is absolutely, completely reliable.
- Romba
Well how much would it cost for you to make one? And how do I charge it when its in the gun? AND what if the battery runs out and I need to put another in it?
A. You can buy one of the batteries for about $20
B. I either rewire the whole pistol to tiny connectors, or use an original battery to steal the connector.
C. Charge it by using the balance plug while the slide is removed. Just make sure it's not plugged in to the gun aswell.
D. It won't run out.
- Romba
So you could make me one for $20? And it wont run out? How many MaH?
You'd have to buy the battery and supply the parts, but I can help you get them.
I want to say 900mah 7.4v 25c, but I'll have to check.
- Romba
OK, I'm confusing myself. Are you saying you would build it if I supplied parts or are yo saying you would want a fee to build it?
You get that parts, and I'll do it for $10 labor. It won't take too long, but I'll have to rewire the gun for the new connectors or else solder on the ones from the original battery.
- Romba
Hmm Alrighty I will need to save some more money, because the gun itself will drain my airsoft funds.
There are a lot of internal upgrades for it, but they are completely pointless. Don't waist your money opening the gearbox, take Stephen's advice.
[align=center][/align]
