VoidSuicide
Post
by VoidSuicide » Tue May 31, 2011 6:48 pm
Back from the dead?
blackout
Post
by blackout » Tue May 31, 2011 7:32 pm
take a direct shot over the hop up and see if the air nozzle is seeable through the feeding hole.
VoidSuicide
Post
by VoidSuicide » Tue May 31, 2011 7:38 pm
Actually, yes I can right now. I take it that shouldn't be the case, right?
Back from the dead?
blackout
Post
by blackout » Tue May 31, 2011 7:40 pm
it would probably be causing it to not feed, but its likely this isn't the problem.
VoidSuicide
Post
by VoidSuicide » Tue May 31, 2011 7:45 pm
Then what would it be? The entire problem is that its very temperamental about feeding and typically doesnt like to feed.
Back from the dead?
blackout
Post
by blackout » Tue May 31, 2011 7:49 pm
Is that one piece hop up new?
VoidSuicide
Post
by VoidSuicide » Tue May 31, 2011 7:55 pm
No idea. I bought the gun pretty much as is from MCG a couple months ago.
Back from the dead?
Rev
Post
by Rev » Tue May 31, 2011 8:00 pm
Is your bucking or nub in wrong? I know it sounds silly I had the same problem then I realized I had installed them backwards.
Also I know you said the mags work in a different gun but have they always worked in this gun?
VoidSuicide
Post
by VoidSuicide » Tue May 31, 2011 8:03 pm
I honestly don't know. I've not had the gearbox apart, and I've never looked at either of those parts out of a gun.
Back from the dead?
- Admin
Post
by SteevoLS » Tue May 31, 2011 9:10 pm
First: Try different brands of magazines.
Second: If the air nozzle is not completely retracted from the hopup unit when the gun is not being fired, it won't let the BBs feed consistently. If that is the case, you could remedy the problem by shaving it down slightly.
In this particular case, my money is on a various mishmash of parts not agreeing with eachother.
VoidSuicide
Post
by VoidSuicide » Tue May 31, 2011 9:32 pm
I'd say the mishmash too. Considering all 6+ mags that have been tried work about the same.
How much is slightly? I know it obviously has to be enough that it doesn't block the hopup unit.
Back from the dead?
Bushmaster
Post
by Bushmaster » Tue May 31, 2011 9:39 pm
Not sure if this'll fix it, but it's worth a shot. When my G36 wouldn't feed because the air nozzle didn't retract all the way I just shimmed the hop-up forward a little using cardboard and it then fed flawlessly.
VoidSuicide
Post
by VoidSuicide » Tue May 31, 2011 9:51 pm
So, I just test fired it a couple times on semi. And it seems that the nozzle is stopping a bit randomly, sometimes clear of the barrel, sometimes blocking it partially or even fully. Could the problem be that something has come loose and that the nozzle not properly attached to the piston or whatever it connects to?
Back from the dead?
Skywalker
Post
by Skywalker » Tue May 31, 2011 10:56 pm
Yeah, it could be out of place with the tappet plate.
I know on one of my guns, the hop up unit just generally wore out after 4 years. I know it sounds like BS, but I tested and replaced every little thing until I just gave in and ordered another hop up. And it fixed it 100%. Although, my issues were more double feeding.
VoidSuicide
Post
by VoidSuicide » Wed Jun 01, 2011 8:47 am
So I guess I will be opening the gearbox once I have some time to do so. I'll post an update when I do.
Back from the dead?
