Wiring question
Wiring question
On my ICS MP5, the gear box is rear wired, but the wiring end immediately at the back of the gearbox with a mini tamiya connector. Then through the solid stock, is another wire that converts it from mini to large tamiya. Ive been doing some experiments this morning and it seems like using the converter causes the gun to lose a large portion of its power and cuts its ROF by more than 1/3. Am i correct in beliving that using these converters, through the multliple connections is the primary cause of the reduced ROF?
And please, no comments about how i need to change my connectors. They are not productive towards my question.
- VoidSuicide
Re: Wiring question
This is interesting... Mainly because my brother's m14 was the same way when I took it apart. In theory I would agree with you about the lower rof as a result.
Re: Wiring question
ok, ripped it all out, and hooked the battery straight to the first connector. worked great. heres a pic of what i took out
5 total electrical connectins before i took it out
Re: Wiring question
You tell us.
? Tamiya connectors are famous for making bad contact
- VoidSuicide
Re: Wiring question
ok, My bro's wasn't anywhere near that bad..
Re: Wiring question
Simple solution: swap out for Deans, XT60s, Traxxas, whatever. Just stay the heck away from Tamiyas.
Re: Wiring question
He didn't want that answer though...
Re: Wiring question
This I realize, but there is no other solution short of running a single piece of wire all the way out of the gearbox. The resistance is high enough on Tamiya connectors that they will always be a significant hindrance.
Re: Wiring question
yeah thats why i eliminated that long peice of wiring garbage.
