I have been wanting to get started on a DMR build but there is a deal breaker. Will an Ajax Customs STS fit in a KWA m16.
I am thinking not because of the split hop-up.
Let me know what you guys know.
I was thinking that I could Fabricate my own out of wood. Wood because the ease of manipulation
STS in a KWA?
Re: STS in a KWA?
It only work with a single piece hopup unit if I remember correctly. I'd pull it out of my SPR and check, but that would end badly for my gearbox (being split in half and all).
Re: STS in a KWA?
Thanks for the speedy reply. I'm pretty sure that I can just put a one piece hop up in there.
Re: STS in a KWA?
Using wood would defeat the purpose, as wood would compress instead of transferring the energy.
Re: STS in a KWA?
Use Sorbo. It's much cheaper than the STS, and will work in any gearbox. Doesn't involve the hop up at all.
Re: STS in a KWA?
I don't think you can put a one piece hopup in a KWA receiver without modifying the lower receiver and changing out the air nozzle.
Re: STS in a KWA?
The mod of the receiver isn't bad, and you can just dremel down the air nozzle ridge if you don't feel like opening the GB.
