Quieting a motor?
cripto
Quieting a motor?
Post by cripto » Mon Sep 19, 2011 3:04 pm
My motor is pulling a m150 spring on a 1800mah 7.4 lipo battery and it is quite noisy. is there anyway i can get the motor to be quieter?
Felix
Re: Quieting a motor?
Post by Felix » Mon Sep 19, 2011 3:05 pm
Buy a new motor, pad the caging/area around the motor. Quiet the gearbox and others might help too
Image[/align]
Post by Star_folder » Mon Sep 19, 2011 3:17 pm
Shim the gears, I'm willing to bet that 90% of the noise you hear is coming from the gears than from the motor. But felix is right, if everything else checks out, it could be your motor is just noisy. What motor is it?
cripto
Post by cripto » Mon Sep 19, 2011 3:23 pm
It's a stock SRC motor. It's got very powerful magnets. The sound I hear is more of a whine than anything. Also, the motor heats up a little after firing the gun for a little.
VoidSuicide
Post by VoidSuicide » Mon Sep 19, 2011 3:26 pm
Something I noticed has been missed so far that can cause whining/screaming would be for the motor height to be adjusted improperly.
Image[/align]
cripto
Post by cripto » Mon Sep 19, 2011 3:44 pm
Yeah, I tried to adjust it, but I guess its kinda stuck, because no matter how much I lower it, it doesn't change the pitch.
Post by SteevoLS » Mon Sep 19, 2011 4:44 pm
In that case, it's probably stuck from the friction caused by the wires in the grip.
cripto
Post by cripto » Mon Sep 19, 2011 9:35 pm
yeah. i can't seem to get is loose. any suggestions?
dftrent12
Post by dftrent12 » Tue Sep 20, 2011 12:37 am
When in doubt, trust the all mighty dom
Is tactical pastel pony
Post by Star_folder » Tue Sep 20, 2011 8:12 am
Try wiggling it a bit, You'll probably need to get some pliers to grip the plastic endbell to pull it out.
Skywalker
Post by Skywalker » Tue Sep 20, 2011 1:09 pm
Those gigantic wires can get tricky sometimes cripto
cripto
Post by cripto » Tue Sep 20, 2011 2:02 pm
Yes, yes they can. any idea on why the motor would be heating up? Is this a bad thing or is it normal?
VoidSuicide
Post by VoidSuicide » Tue Sep 20, 2011 2:24 pm
As far as I know, a little warming is normal when it's getting a lot of use. About the only thing i can think of that might help keep the temp down some would be a mosfet, which lowers the strain on the gun's electrical system.
Image[/align]
cripto
Post by cripto » Tue Sep 20, 2011 2:34 pm
yeah its already got a mosfet in it. I fiddled with the motor heigt and I got the motor to be much less whiny. Problem solved(for the most part). Thanks guys! I really appreaciate the help!
Cody C.
Post by Cody C. » Tue Sep 20, 2011 8:34 pm
A hot motor could just be because it is pulling an M150 and is under immense stress.
