In the process of getting all the parts i need to build me a dmr. I am wanting to know if this stock will fit on my gun. Also if the front triangle sight on this gun is removable have not received the gun to check for myself
gun: http://www.airsoftpost.com/product_info ... s_id=30906
stock: http://redwolfairsoft.com/redwolf/airso ... _Black.htm
Will this stock fit on my gun
Re: Will this stock fit on my gun
Yes, unless there is something weird about the agm that I don't know about.
If that gun is rear wired (probably, with that stock) then make sure to get a nice little lipo to fit in the prs stock... or be ready to do some custom work.
- Avenger
Threads like this should be in the technical topics thread Nabors, not General Discussion. Just a heads up
You are the last person on the forums that should be telling people where to post things. If it needs to be moved it will be.AnthonyRey999 wrote:Threads like this should be in the technical topics thread Nabors, not General Discussion. Just a heads up
- Echo1 Operator
- Echo1 Rep
The PRS stock is heavy and will probably end up breaking the pot metal receiver on that gun in the long run.
As long as it isn't too abused, throwing and dropping it and such, it should be fine.airsoftsniper11 wrote:The PRS stock is heavy and will probably end up breaking the pot metal receiver on that gun in the long run.
- Avenger
Or you could upgrade you reciever as well, I don't think it's too expensive.
- VoidSuicide
He could do that, but unless he's like steevo with an ability to pull super bargains out of the air, I wouldn't exactly call it cheap. The cheapest metal receiver set on airsoft atlanta is an out of stock JG set for $50. on airsoft gi, the cheapest is a G&G set for $100.
