KWA M4 not firing properly
TokenTech89
Post by TokenTech89 » Mon Nov 14, 2011 3:51 pm
i read on another thread about the bucking issue, but wwith my friends M4, it won't shoot semi, but will shot every other one in full auto.
Any thoughts about this problem.
Re: KWA M4 not firing properly
Post by Dominum » Mon Nov 14, 2011 4:23 pm
What do you mean it will shoot every other one in full auto? Do you mean that when in semi it functions the same as full auto, or something else? Be extremely specific as to what the symptoms are.
TokenTech89
Post by TokenTech89 » Mon Nov 14, 2011 4:31 pm
it doesn't double feed. rather it alternates between dry fire and actually firing a bb out. in semi fire, it doesn't fire any shots at all, basically dry firing the entire time in semi mode.
Post by Dominum » Mon Nov 14, 2011 4:33 pm
OK, so, in full auto the gun only fires a BB out every other cycle; In semi auto, it does nothing but dry fire?
TokenTech89
Post by TokenTech89 » Mon Nov 14, 2011 4:36 pm
Dominum wrote:OK, so, in full auto the gun only fires a BB out every other cycle; In semi auto, it does nothing but dry fire?
exactly. :D
Post by Dominum » Mon Nov 14, 2011 4:41 pm
Is it entirely stock?
When it does fire, does it do so with a normal trajectory, or does it basically roll out of the barrel?
Have you fired it with the hopup turned all the way off?
TokenTech89
Post by TokenTech89 » Mon Nov 14, 2011 4:44 pm
it is entirely stock, no internal upgrades what so ever.
when it does fire, it shoots out like it would. we brought it out to Op24 in hopes of using it, but we could not because of the problem
and I tried it not long ago with the hop-up all the way off and all the way up. both gave the same results.
it is really confusing with this one....
Post by Dominum » Mon Nov 14, 2011 4:48 pm
Can you take quality video of the magwell when firing in both settings so that I can see how far back the airnozzle is going during it's cycle?
TokenTech89
Post by TokenTech89 » Mon Nov 14, 2011 6:12 pm
i took a look inside the magwell, and did a few test shots, the airnozzel diesn't go fully back after the trigger was released. both in semi and in full auto. a little still sticks out, preventing the next bb from sliding up.
Post by Dominum » Mon Nov 14, 2011 6:56 pm
That could be a number of things, but the easy fix is to shim the chamber against the shell.
TokenTech89
Post by TokenTech89 » Mon Nov 14, 2011 6:58 pm
Dominum wrote:That could be a number of things, but the easy fix is to shim the chamber against the shell.
that, my friend, is where i will leave that up to the professionals to do. i hope the ace hardware store can do repairs like that, or someone near here can do that
Post by Dominum » Mon Nov 14, 2011 8:21 pm
I don't think the ACE hardware store guys know what a hopup chamber even looks like. It's not hard, just put something between the two.
TokenTech89
Post by TokenTech89 » Tue Nov 15, 2011 8:36 am
true but still, i rather let someone who has done it before than i try to do it and mess it up. who is close to charleston, or sumter area that can possibly fix it?
Post by Star_folder » Tue Nov 15, 2011 9:20 am
I suggest going through the Services Sale forum. It's at the bottom of the main page. There are a few of us that offer tech work, I could take a look at it, but I live in lexington.
