Clamp on rails and sling mounts
Akaishinobi
Post by Akaishinobi » Sat Jan 28, 2012 7:07 pm
Does anybody know of rails or sling mounts that clamp on to the barrel of rifles?
Akaishinobi a.k.a. Smoke
severed
Re: Clamp on rails and sling mounts
Post by severed » Sat Jan 28, 2012 8:57 pm
yep, google is your friend as well as just searching through the external upgrades or accessories sections of airsoft websites.
Akaishinobi
Post by Akaishinobi » Sun Jan 29, 2012 10:13 am
severed wrote:yep, google is your friend as well as just searching through the external upgrades or accessories sections of airsoft websites.
Considering the oddness of what I'm searching for, airsoft sites tend not to have what I'm looking for, and finding actual places to get real steal accessories is hard sometimes I'm not sure about the clamp on sling mounts I found. I'm not sure they are the right size to fit on the barrel and I don't exactly have a way to find out.
Avenger
Post by Avenger » Sun Jan 29, 2012 10:36 am
If the stock is strong enough to support the gun, drill a hole through it and the foregrip(wherever you think will work the best for you), insert key rings and ta-da! Sling mounts.
Akaishinobi
Post by Akaishinobi » Sun Jan 29, 2012 10:39 am
Avenger wrote:If the stock is strong enough to support the gun, drill a hole through it and the foregrip(wherever you think will work the best for you), insert key rings and ta-da! Sling mounts.
Got it. I figured something like that may be good. There's my rear sling mount Thanks.
I'm looking to find/make a custome clamp on front sling mount as well
