KWA SR7
KWA SR7
Hey guys. I just got a KWA SR7. I got it because I play a lot of CQB. Now I want to start playing milsim and want to upgrade this one, and leave my other KWA M4 for CQB. I am going to OP SOCO in March and wanted a basic upgrade before then. The gun shoots 360 fps stock, and I want it closer to 425. I am wanting to put in a new spring, but don't want to wear out any parts since I will not do any more uogrades until after the OP. I am between a Systema M130 and M110 spring. Any ideas on which to do and what the effects will be? Thanks for any input!
OP Call of Battle Terror in India
OP Steel Griffin Convoy
OP Apple Pie
OP Apple Pie
Re: KWA SR7
Stock KWA springs are equivalent to an M120-130 already. I'm guessing it's a CQB length rifle? Shorter barrel=lower FPS.
Re: KWA SR7
You sure you want 400+ fps? With that you would have an 100 MED and can only use semi. I love having guns around 360 fps and i have a kwa sr10, saw, and f2000. But if you really want fps that high then get a m130 spring, longer barrel, and a mock suppressor to hide the exposed inner barrel. But you have a good gun that would be great in the field with it being all stock.
Team Insert Name Here - I.N.H CO
A&K M249|H&K G36CV
OP: Crisis In Dunundistan II
OP: Flash Heaven
OP: Second Sun
Escue Airsoft Mini-games
Auguest 4th Airfarm games
A&K M249|H&K G36CV
OP: Flash Heaven
OP: Second Sun
Re: KWA SR7
The main reason for me wanting higher fps is because I don't know how big the place is and wanted to make sure that my gun had the range to hit any target I might come upon. It does sound like I am going to hold off on an upgrade, though. I will eventually put in a tightbore barrel and maybe a spring, but not yet. Thanks!
OP Apple Pie
OP Apple Pie
