My Dad is worried that the gearbox in his stock KA M4A1 Sportline gearbox is going to explode. He's running a 11.1 lipo from Dom and it's CRAZY fast. I'm talking minigun.
Is his gearbox going to explode, and what preventative measures can be taken?
A little help
- Avenger
A little help
- Avenger
Re: A little help
None at all... Yet.
Re: A little help
PLEASE TELL ME YOU USED THE MAGICAL THING CALLED "GOOGLE" BEFORE YOU POSTED THIS.
https://www.google.com/search?hl=en&rlz ... l24j6l30l0
LEADS YOU TO
http://www.airsoftsociety.com/forums/f3 ... ipo-41704/
....*eye rolling emoticon*...
Yes, no mosfet or upgraded internals; something is going to give way much sooner than normal while using a 11.1.
Upgrade the gun to handle the voltage. Or use a different battery, like a 7.4v lipo
LEADS YOU TO
Re: A little help
I have to post in every topic in the technical forum because I have to post in every topic in the technical forum.
Basically what Skywalker said. Your gun will break eventually, and most likely, it'll be your piston. But to run an 11.1v without worrying much about your system, you need 3 things. AoE corrected, shimmed gears, and a mosfet, in that order of importance. AoE so the piston doesn't die, Shimming so the gears don't eat themselves, and mosfet to protect your trigger contacts. The AoE is the most important because your piston will take the most of the damage. Your gears are a little more resilient, but are still breakable if the shimming on them is THAT bad. And, depending on the strength of the battery, the stronger the battery, the more it will damage your trigger contacts.
