BBs
BBs
If I buy a KWA CQR, I should most likely not use my Crossmans to go with it, so, are Goldenball bbs ok? Not sure if this is the right thread sorry if it is not
(Stolen from Gerbilizer
- Avenger
Re: BBs
I strongly suggest King Arms .25s. They are very accurate, and the only jam I've had with them was caused by sand at Blue Hole. They aren't hard to find, Academy Sports near Columbia carries them.
Although, the Crosman BBs won't hurt your gun unless it has a very tight barrel.
Re: BBs
If you put crossman in that gun kick yourself in the face. G&G are great bbs and they are inexpensive.
Re: BBs
I've used Crossmans my whole life, and never a jam once, even at Blue Hole. But you are right, I did see some G&G bbs on Airsoftr GI the other day, thank you for reminding me.
Re: BBs
The Crossman hate is a little behind the times. I've put at least 50k through my AKM, and I even ran a thousand or so through my old VFC. If you're running .20s for some reason, you can't beat the value. When it comes to heavier weights I use King Arms.
Re: BBs
Golden Balls in my experience are the best even though you have to order them probably there still the best you can get them from megastore for $10 for a pack of 4k.
