Ok, I just bought a Matrix irregular pitch m130 spring for my KWA SR12. I open the gearbox up, fix the AOE with a 70D 1/4" Sorbo pad, then covered that back up with the stock rubber pad from the piston head. When I went to put the spring it, it just will not fit in the gearbox. It's not a matter of strength as I am a big dude, so what can I do to solve this other than taking the Sorbo off. Can I cut the spring a bit and how much would that affect the FPS?
Thanks in advance.
M130 Spring Problems
Re: M130 Spring Problems
call dom http://www.southcarolinaairsoft.com/php ... f=3&t=5649 he knows a lot about that stuff and if needs be can fix it for you
Ok, will do. Thanks.
Your spring will fit in your gearbox. It's not because of your sorbo padding that it isn't fitting, you just need to try harder.
