So I took apart my javelin m16 to find out that the 6mm stainless steel modify bushings I got are not the right size. I have been trying to figure out what size they are. I can't seem to find a reliable answer. if anyone knows what size they are i would be greatly appreciated.
The m16 i have:
http://www.airsoftgi.com/product_info.p ... ts_id=7528
Javelin m16
Re: Javelin m16
It's actually a pretty easy solution. If what you have now is 6mm, and you want to know if the bushings in the gun are 7mm or 8mm. If your 6mm bushings can fit all the way through, you can drop them through the hole, then they are 8mm bushings. If they don't go through the hole, but wobble around a bit, they are 7mm bushings.
Re: Javelin m16
They dont fit they wobble around but every place I looked is saying 8mm.
Re: Javelin m16
When in doubt, get both. At least you'll have spare parts.Nabors wrote:They dont fit they wobble around but every place I looked is saying 8mm.
Besides, bushings aren't terribly expensive either.
