TM HK USP AEP
Iam_Hoss
TM HK USP AEP
Post by Iam_Hoss » Thu May 24, 2012 8:25 pm
I bought this used and now I find out it does not fire. It Has TM Pro-light. I charged the pro-light. It holds a charge as the light turns on. I also checked the fuse in the external power converter. Any thoughts on what it could be. Per the previous owner it worked fine the last time they used it a couple years ago.
The last game I attended was- Op Iron Marches
Polarstar refills here- HPA REFILLS
Re: TM HK USP AEP
Post by SteevoLS » Thu May 24, 2012 8:41 pm
Does it make any noise whatsoever when you try to fire?
Iam_Hoss
Re: TM HK USP AEP
Post by Iam_Hoss » Thu May 24, 2012 8:42 pm
No Sound at all
Re: TM HK USP AEP
Post by SteevoLS » Thu May 24, 2012 9:02 pm
It's an electrical issue then. It might be a broken solder joint, the pro-light might not be sending power through the battery connector, or the trigger might be damaged. I would test the prolight connector with a meter and see if it's sending any juice.
Iam_Hoss
Re: TM HK USP AEP
Post by Iam_Hoss » Thu May 24, 2012 10:06 pm
Not sure on the trigger. But I did notice that when the gun is on safety the trigger moves.
I checked the pro light and it has power at it's connector. I checked the external battery connector and it has power when connected to the light.
I do not know how to pull the motor to check the connections there.
Avenger
Re: TM HK USP AEP
Post by Avenger » Fri May 25, 2012 9:31 am
I know that this isn't really related, but did you buy this from Airsoft Atlanta?
Re: TM HK USP AEP
Post by SteevoLS » Fri May 25, 2012 9:39 am
Iam_Hoss wrote:I bought this used
Iam_Hoss
Re: TM HK USP AEP
Post by Iam_Hoss » Fri May 25, 2012 10:00 am
Avenger wrote:I know that this isn't really related, but did you buy this from Airsoft Atlanta?
No I did not but why would that matter?
Gambler
Re: TM HK USP AEP
Post by Gambler » Fri May 25, 2012 12:55 pm
Airsoft Atlanta does not sell this AEP.
Iam_Hoss
Re: TM HK USP AEP
Post by Iam_Hoss » Fri May 25, 2012 3:05 pm
Any other ideas on how to get this AEP working?
Avenger
Re: TM HK USP AEP
Post by Avenger » Fri May 25, 2012 5:11 pm
When I was in there(AA) they had a used TM HK USP AEP which I almost bought.
Iam_Hoss
Re: TM HK USP AEP
Post by Iam_Hoss » Fri May 25, 2012 8:24 pm
Avenger wrote:When I was in there(AA) they had a used TM HK USP AEP which I almost bought.
Yeah I saw that one on Saturday for $45.00 they had in the boneyard pile. if I had only bought it I would have some extra parts to get this one running.
