Upgrades for jg r36c
I want to up the performance of my jg r36c and was wondering were can a get a better gearbox for it I can't find one and sometimes my gun stops firing at random and I have to take all apart and put it back together and it works any idea why?
PAIN is weak leaving the body
Op: ice cubed
Op: ice cubed
Re: Upgrades for jg r36c
Can you describe the problem a bit more? When your gun stops firing, does the motor click in the gearbox? And how far do you have to take the gearbox apart?
What battery are you using with the gun?
[/align]Re: Upgrades for jg r36c
It will be fireing normaly then all of a sudden it will stop first time it happened i thought i blew the fuse but checked the fuse and it wasnt blown and second time i was in the middle of a battle and it stoped (sucked had to pull out the old sniper) and afterwar when you pull the trigger it sounds like the batery is dead but its not so i take the gear box out of the gun do nothin to it put it back in and it fires as normal right afterward
Op: ice cubed
Op: ice cubed
the batery is a jg works 1100 mah 8.4 volt
Op: ice cubed
Op: ice cubed
slimshady222
You probably need a new motor or a more powerful battery same thing happened to me.
ok what battery should i get and were should i get it from and how much?
Op: ice cubed
Op: ice cubed
- Avenger
Google is your friend. Really.
slimshady222
I buy all my batterys from either gi or megastore both are great.
SHS are cheap and good, Lonex are a little more expensive but have much better Quality Control than SHS.
Though I would just get a better battery. Do some research into 7.4v lipo batteries. They can be about the same size as your 8.4v but will pack a much stronger punch.
[/align]-
TokenTech89
try investing in a 7.4 lipo battery like star said, it seems like the battery isn't putting enough power.
Can you use a Lipo with a stock gear box? And how do I increase range and fps
Op: ice cubed
Op: ice cubed
marpat96
Yes you can use a lipo on a stock gearbox, just make sure its a 7.4v lipo. Leave your fps the way it is, those guns should shoot around 370-400 fps with a .20g BB, and if you want more range, you can buy a better hop up bucking and nub than the one you have now, or you could get you gun flat hopped.jakger wrote:Can you use a Lipo with a stock gear box? And how do I increase range and fps
(Stolen from Gerbilizer
