(re)Build of VFC Scar-H SSR
Alright all, since Frost is starting threads about builds, I'm going to start threads about builds. There will be no cutting corners.
Custom Masada PRS stock on the gun, and even more custom fitting a battery inside that stock. I believe I can get a stick type 11.1v 20c 1600mah in there. Not the biggest battery in the world, but it'll have to do. My only other option for more juice would be running two lipos, and they're supposed to be identical batteries to do that.
Power goes to a Chimera mosfet, and yes, I have to find a place for the brick of that mosfet too.
The motor I have in there is a G&P M170 Devil Jet, which should do the job. I still don't own a Lonex motor, but I don't think its worth replacing the Devil Jet to get one.
RiotSC gearset. Enough said there.
Existing piston needs to go, its a half tooth. I'll probably just get a SHS Blue piston for replacement.
AOE corrected.
Sorbo added.
Any strong opinions on piston heads? Otherwise I'll stick with something metal; whatever I can get my hands on that's decent. I may go ahead and add a slightly larger O-Ring though.
SP170 it shall be.
Radius GB shell
Metal Hop up unit. I've never cared about that before. Additional opinions?
Appropriate hop up mods.
Prommy 6.03 .... 509mm I guess
AOE corrected.
Sorbo added.
SP170 it shall be.
Radius GB shell
Re: (re)Build of VFC Scar-H SSR
Ok... Maybe not. Assuming I want to retain function of the adjustable cheek riser. I could scrap all those parts, attach the riser permanently, and probably fit this battery.... but. I'm going to look into a 2 battery approach.
You might have more success using a split-cell butterfly battery.
- 2nd Ranger
metal hop up unit for a VFC SCAR SSR? I did not know there was one made?
agi is selling lonex convex polycarb heads for $12
AEA airsofter, Anywhere Everywhere Anytime
Last Game OP Vietnam Patrol - US CO - Win
THANK YOU!!
THANK YOU!!
I say this only BC you say no cutting corners why not go with a orga wide bore barrel 6.23 or a pdi 6.05?
|VFC M4 "Dirty Harry"|
Well, I MIGHT go with the 6.05, I'd have to look into them a little bit more.Frost wrote:I say this only BC you say no cutting corners why not go with a orga wide bore barrel 6.23 or a pdi 6.05?
From what I've seen about the orgas, they work well with polar stars when you have plenty of extra air volume. But the advantage on an AEG is debatable. And I'd prefer the higher fps of a tighter barrel.
Orga makes a 6.13mm version of their barrels, that might work.
[align=center]V[/align]Romba wrote:I just want to shoot everyone.
They make a coated 6.13mm version. For top of the line, coated barrels are never an option.
[align=center][/align]
well I love my pdi 6.05, and I have used prometheus 6.03 and felt like the pdi were superior. Now if they are worth the difference in price for the amount of performance is the question. Most say no. I happen to just get my pdi at a discount.
Looks like I'll be able to fit the brain of the Chimera and a decent battery in here after all!
oooooooh aaaaahhhhh. nice choice of mosfet. Im looking forward to see the results after your rebuild is finished.
Frost wrote:oooooooh aaaaahhhhh. nice choice of mosfet. Im looking forward to see the results after your rebuild is finished.
im not
....He he he....thebutnugget wrote:Frost wrote:oooooooh aaaaahhhhh. nice choice of mosfet. Im looking forward to see the results after your rebuild is finished.
im not
