HEEELP!!! Snapped upper and lower
ShadowRRS
I have an ICS proprietary split gearbox M4 and have dropped it enough (actually, friends dropped it enough) that the lower receiver has snapped at the stock and the upper has snapped at just below the handgaurd. If anyone has any ideas on how to fix it, post below. if you know of a place I can get the receivers cheap, pm me as it would be in the wrong section if you posted.
Re: HEEELP!!! Snapped upper and lower
The problem with ICS is that the body is just as proprietary as the gearbox. So unless you can find one used, you're out of luck, and it's time for a new gun.
You might be able to find one in a bone yard somewhere, and just pull the internals out of it to put your working internals in it.
[/align]-
ShadowRRS
That's what I figured, I'll look around a little bit more.
