RHop on a low fps setup.
MrBlond
Post by MrBlond » Thu Jul 25, 2013 11:22 am
Everything i have read on rhop said it was for heavier rounds and such. At a lower fps the contact time would be longer and i would think less stress on the gearbox so more consistency. I would think the results would be more consistent hop up can anyone confirm what would happen a sub 350 fps setup with .25s?
Stomper87
Re: RHop on a low fps setup.
Post by Stomper87 » Thu Jul 25, 2013 11:55 am
R hop is fine for low fps set ups. Some people have managed to get a good hop on even a .12 gram bb. You might be thinking of the ER hop, which is used for heavier rounds
P* Ares Tar21
P* PTS Masada
Magpul KWA lm4
KA Galil SAR
G&G UMP
G&P ak47
CA mp5a4
MrBlond
Post by MrBlond » Thu Jul 25, 2013 1:19 pm
Yes how would er hop do with a gun under 350 fps with .25 although using even heavier rounds?
Post by Star_folder » Thu Jul 25, 2013 1:23 pm
Sub 350 with .25s isn't really a low fps set up. People use that all the time, I would throw an estimate than 60-80% of the guns in the state shoot in that area, and I know quite a few of them have r-hops, along with the plethora of people who have put r-hops in their own guns shooting in similar areas.
Your results are dependent on the quality of the install, air seal, and bbs used, not the fps.
Same with an ER-hop. It's not fps dependent, it's weight dependent. There's a reason it's advertised for bbs greater than .30gs. Ideally, it's good for .4s. And while you might have some awesome range and accuracy, your bbs will still float to their targets, not to mention, .4s and full auto are something to consider.
Post by Dominum » Thu Jul 25, 2013 4:22 pm
FYI: While a less powerful spring does translate generally to less stress on most internal components for (obvious reasons), that does NOT necessarily translate into more FPS consistency. The consistency of the FPS is primarily based on the air seals between various components, and on the consistency of the manufacture of the BBs, barrel, etc.
i.e. consistency breeds consistency.
