Nyte Stalking Equipment
Pictures and descriptions of your armory!
Nytestalker
Post by Nytestalker » Wed Feb 16, 2011 11:32 am
First up is my two sniper rifles.
CA M24-Zero Trigger W 3 Element piston
-CA Reinforced Cylinder
-PDI hopup
-PDI 6.01 inner barrel
KJW M700 Gas-powered
[img width=576 height=1024]http://i1139.photobucket.com/albums/n54 ... 0_0025.jpg[/img]
KWA SR10 w/ Mosfet
G&G UMG
-6.03 Promethius inner barrel
ICS M4 CQB
-6.03 inner barrel
-Systema Cylinder & Piston Head
-Reinforced Piston
[img width=576 height=1024]http://i1139.photobucket.com/albums/n54 ... 0_0024.jpg[/img]
Lastly is my new addition.
I actually got this for free if you can believe it.  I traded my SR-12 for the SR-10 and this KSC Glock 26C plus all 6 mags.
[img width=1024 height=576]http://i1139.photobucket.com/albums/n54 ... 0_0026.jpg[/img]
Vesper
Re: Nyte Stalking Equipment
Post by Vesper » Wed Feb 16, 2011 10:41 pm
How is the performance of each gun?
Nytestalker
Post by Nytestalker » Thu Feb 17, 2011 12:19 am
M24
-435fps w/.30
very consistant and I am not sure about the range.
M700
-I was very suprised by its performance with being a stock gun
-480fps w/ .20
-It outranges my M24 but is alot less consistant
UMG & M4 CQB
-both have a decent rate of fire and with both shooting around 320fps w/ .20
- The ICS shoots great and actually has about the same range as my SR-10, plus I love the split gearbox design; it makes changing the fps a breeze.
SR-10 & G26c
-both are stock but not for long
-Planning on using the SR-10 as my platform for a custom gun I have been wanting to build
-And the Glock will probably be getting some goodies added to it in the near future.
Vesper
Post by Vesper » Thu Feb 17, 2011 12:25 am
How do you change your FPS on ICS M4? Do you have to change the entire upper gearbox, or is there a spring guide that screws out like Ares gearbox? I'm thinking about getting an ICS AEG, but I'm just not sure yet.
Nytestalker
Post by Nytestalker » Thu Feb 17, 2011 12:34 am
You have to change the spring out but all it is is 7 screws. But you don't have to worry about the other things such as the gears or wiring.  Plus for $30 you can buy another upper shell and put another setup in it.  Then you just pull out the back pin, pull the upper shell out and put the new one back in.  320 to 400 in less than a minute!
Post by Dominum » Thu Feb 17, 2011 8:47 pm
Nice collcetion, if you ever want to sell that 26 let me know, that way I can be the only one around here again.
Vesper
Post by Vesper » Thu Feb 17, 2011 9:50 pm
Nevertheless, I think it's a pretty cool design. I'm getting sick and tired of opening my gearbox just to change the spring. After every switch, I'm pretty much brain dead.
stuckmojo
Post by stuckmojo » Sun Feb 20, 2011 10:34 am
if you ever want to sell that sr10 let me know.  im sure you wont but just in case you do
Nytestalker
Post by Nytestalker » Sun Feb 20, 2011 10:58 am
Probably not.  It is actually completely tore down right now.  I am doing a complete custom set up on all the way from body to internals.  I will actually post everything I am will be doing to it as I go along.
theboss62
Post by theboss62 » Sun Feb 20, 2011 12:06 pm
is the silencer crooked on the UMG? sure looks like it is come off at a wierd angle
Team AJAX
Arsenal- in the works
Nytestalker
Post by Nytestalker » Sun Feb 20, 2011 5:51 pm
Yeah.  It wasn't locked in place right and I didn't notice until the other day when I tried to fire it and the bbs just hit the silencer.
