I had not realized I had this many guns. I may end up clearing some out, but for now...
My CYMA G18s, Panty and Stocking.
I would say they're twins, both getting the same use and repairs. I never have one without the other. Currently have only done a bit of a flat hop mod attempt on each to squeeze a few extra feet out of them.
The nearing famous Echo 1 ASR.
This was originally going to be for gits and shiggles, but it has turned into my main project gun, and I would call it my baby. It's gotten quite a range of responses from those who've seen it. As for upgrades it now has a new steel cylinder and a downgraded spring putting the FPS right under 300 with a .25. On it is a red dot sight/scope and a functioning 110mm silencer. I'm also planning to try to modify an AEG grip to fit on it.
CYMA M14
Added a CYMA M14 RIS and swapped to deans. Currently planning to upgrade it to by a DMR/sniper rifle in the range of 500 FPS.
CA M249
Got it from Robin new with AEX upgrades. Haven't done much with it because I continue to fight it the mag and its feeding issues, but when it's working it gets attention. (Ask Kory about the time I was at his place)
CA M14
I got this for my brother and have wound up stuck with it. Have since replaced the piston/piston head, wired it with a MOSFET. Shoots really solid for CQB level FPS.
Not pictured: Echo 1 SCAR that is under construction, walmart shotgun, and a pair of near useless plastic spring pistols.
