2x CA box mags (they've been slightly modified with a toggle switch instead of a pressure switch)
Phoenix Mk46 outer barrel set
G&P steel bipod
CA Railed upper tray feed cover
G&P Ranger Pistol grip
G&P Mk46 butt stock
ELANE (ELCAN) illuminated redicle scope
G&P v2 gearbox (piston, gears, etc)
TM EG1000 motor
ACM M249 Upper RAS
ACM M249 Lower RAS
Deans plugs, too.
Not sure what the FPS, range or accuracy is like just yet (my backyard isn't big enough to test that)
Here's the pictures.
I really need a new camera.
