THE FOLLOWING AIRSOFT EVENT IS NOT AFFILIATED, SANCTIONED, OR SPONSORED BY THE A.O.S.C. Event organizer ACCEPTS ALL RESPONSIBILITY OF SAID EVENT.
http://www.scairsoft.com/forums/http://www.southcarolinaairsoft.com/newforums/viewforum.php?f=6.0
Quoted from Sean on the SCAA forums:
The field is on 30+ acres of land that is split between 2 roads, and a swamp behind the skeet range. So that will give us 3 different fields to play on, there are no man-made structures, it is pretty much flat land with thick vegetation, trees, lots of trails and a little creek that might have water in some places. This field is next the Ft. Stewart Trap and Skeet Range Club so please park on the opposite side of the reserved parking spots for the skeet shooters. (the left side when entering the facility)
As always this game it is open to all ages. All players must wear ANSI 87.1 rated eye protection inside game boundaries at ALL times; no exceptions will be made to this rule. Those under 18 will have to wear a full face mask and a parent there to sign waiver. If you have any questions feel free to post as I will be checking this post in case anybody does want to show.
There is a restroom on site and is VERY clean, no other amenities are there. Please bring lots of water and other things with you.
The weather is going to be HOTTER so please bring water with you and a way to carry it onto the field while playing, ie: Hydration Carrier, Canteens, etc
Cost of the use of the field is only $5.00 for the whole day per person.
If you are going to show, please show up before the game starts, Load your mags and such the night before, or show up earlier to do so.
Game starts promptly after the Safety Briefing at 0800 hrs (thats 8:00 a.m. for the civilian types). to approximately 1500 hrs.
**The field is home to a couple platoons of ticks and a couple squadrons of mosquitoes so make sure you get bug spray with 100% DEET**
If you are planning to attend this game, PLEASE post that you are going to be there. This will help in planning for Scenarios.
If we do not get at least 8 players posting to show, the game will be cancelled, Some spend a lot of money on gas and long distances to get the game, and not to have to turn back around because there was no players there.
Directions to the field:
FROM I-95, NORTH, take Exit 90. at off ramp go West (right turn) on GA route 144. Travel approx. 15 miles, you will see a stone and brick sign that reads Holbrook Pond Recreation Area turn left, keep going down this road until you come to a stop sign, go through the stop sign and take your first left at Skeet Range Rd. you will see white signs along the tree line with paintball in progress.
FROM I-95, SOUTH, take Exit 90. at off ramp go West (left turn) on GA route 144. Travel approx. 15 miles, you will see a stone and brick sign that reads Holbrook Pond Recreation Area turn left, keep going down this road until you come to a stop sign, go through the stop sign and take your first left at Skeet Range Rd. you will see white signs along the tree line with paintball in progress.
Small Local Games in Hinesville, GA
- Doublewolf
