Airfarm
Address:470 Halfacre Rd. Newberry, SC
Date:
Saturday, February 15st
Price:
$20
Itinerary:
8:00 - Registration and chrono opens
10:00 - Game on - round 1
11:00 - switch sides
11:15 - round 2
1215 - lunch break
02:00 - round 3
03:00 - switch sides
03:15 - round 4
04:15 - switch sides
04:30 - round 5
05:30 - score tally
I would also make a note encouraging people to bring ammunition on the field with them to sustain 2-3 hours of heavy combat. These times are subject to change.
Game mechanics:
-All bases have been linked in a linear “chain” of bases. Each base marked is an objective, but must be captured by taking one base at a time in a specific order.
- Each team will take turns attacking and defending each base for a set amount of time before being pushed back to a previous base, or advancing to the next base.
- Hint: Think tug-of-war airsoft.
- A coin will be flipped at the start of the game to determine who attacks first.
- The attacking team will have 5 minutes to capture the defenders base.
- If the defenders keep the attackers at least 10 feet from the capture point for the 5 minutes, they become the attackers and the now defending team must fall back to defend the previous base.
- If the attackers get a player within 10 feet of the capture point, it automatically captures the point and puts their team on the defensive for the point they captured and the clock is reset to 5 minutes.
There will be, at minimum, three admins on duty at all times during this event. One Admin will be stationed at the contested base; the other two will be at each teams respective re-spawn points.
For the majority of the time, your re-spawn will be at a known base location, however, there are a few instances where you will be re-spawning closer to the contested base to make it an even fight.
Admins will alert the players to a change in the base capture status; as well as get players to fall back to defend when a point is captured or defended.
After a base is defended for 5 minutes, the team who successfully defended must gather their forces at the captured base and hold off attack for 60 seconds until beginning an attack on the next base.
These 60 seconds give the now defending team, time to prepare, and the now attacking team time to gather troops. The 5 minute defend timer will begin after the 60 second pause.
This will be a very fast paced game play with non-stop action on one objective at a time.
The round is over if a team pushes the other all the way to the end of the chain of bases, or after an hour of fighting. Each time a base is defended successfully for 5 minutes, a point is given to that team.
Rules:
-Thirty second heal, max two consecutive heals, all friendlies are medics
-For this game, Alpha will have channel 2, and Bravo will have channel 3. This is to allow admins to alert both teams quickly of base capture status and orders to fall back or advance to the next base.
-Remember, if at any time you have a question, use channel 1.
-Deadrags required (it's been a rule for some time, there's no excuse)
-Bring a radio or you won't know what is going on
-If you have both sets of camouflage, BRING THEM BOTH! It will be important to balance players in this game type.
-Channel 1 is for admin, call me on channel 1 if you have any problems or questions at any time.
-Stay hydrated! Just because it's winter doesn't mean you can become dehydrated.
-AOSC games always go on as planned, no cancellations for weather.
Waiver:
If you are UNDER 18 years of age and will not have a parent or legal guardian with you at registration to sign, have them sign one now and bring it with you:
PDF File
Word File
Important Reminders:
-You need to be IN LINE for Chrono and Registration BEFORE 0900. That means you need to show up at 0800, or 0830 at the very latest.
-Mixing tops and bottoms of cloths of different faction colors is NOT OK. It is a violation of the rules and you will be required to change.
-Camping is allowed Friday night. Make sure fires are extremely well contained and supervised by an adult at all times. Be respectful of others in the vicinity in regards to noise, etc. An outhouse will be on site.
