Scenario:
Factions:
Alpha - PMCs
Bravo - NEST forces
Both factions need to locate Trailblazer, but due to its volatile cargo, it cannot be moved. Trailblazer is secured by multiple systems. Access to the container requires successful completion of secondary objectives. The
first team to fully secure Trailblazer wins.
Cost $20
Schedule:
0800: Registration and chrono opens
0930: Briefing begins
1000: Enter the field and game begins
1330: Lunch break
1430: Game resumes
1800: Game ends
Note: There will be strict enforcement of this schedule. Additionally, coms are vital for this game. Information will be rapidly dispersed and being unaware of the objectives/situations will be detrimental to your team. I will be allowing players without a radio to borrow one, provided you deposit $10. Deposit is returned when radio is returned in same condition issued. I have approximately 10 radios to lend.
Address: 1205 Founders Road, Lexington, SC 29073
Everyone will need to sign the waiver before they can enter the field.
You can find it here -> SQA Waiver
-Thirty second heal, max two consecutive heals, all friendlies are medics
-Bravo has odd channels, Alpha has even (as always, no going on enemy channels) Channel exclusions listed below.
-Deadrags required (it's been a rule for some time, there's no excuse)
-All AOSC rules apply
-Bring a radio or you won't know what is going on
-Channel 1 is for game admin ONLY. Call the game admin if you have any problems or questions at any time.
-Channel 2 is for Alpha admin, Channel 3 is for Bravo admin. There will be no CO's for this game. The respective admins will relay info and intel.
-Stay hydrated!
-0 MED weapon is recommended to help clear trenches
-AOSC games always go on as planned, no cancellations for weather
Thanks to SQA, we will be having a raffle including a G&G Combat Machine along with other items!
Important Reminders:
-If you show up after we have begun play, check in at the registration desk. It is NOT OK for you to take the field without having registered and chronographed first.
-Portajohn on site, debit and credit cards accepted, field rental guns are available, SQA sells BBs, Green gas, snacks and drinks, potable water provided to fill containers.
-Players under the age of 18 are REQUIRED to wear FULL SEAL eye protection and proper facial protection. ANSI Z87+ rated shooting glasses are allowed as long as the wearer is age 18 or older. It is highly recommended to use some means (ex. strap) to keep the glasses securely in place. Most mesh airsoft goggles are acceptable and are considered full seal. The field owners will be removing any players caught violating this rule. Please protect your eyes!
