PBC (Paintball Central)
Address: Paintball Central
318 Tucapau Road
Wellford, SC 29385
Date:
Saturday, August 22nd
Price:
$15
Itinerary:
0800: Registration and chrono opens
0915: Briefing begins
0945: Game begins
1230: Lunch break
16:45 Game ends
Scenario:
With the success of this scenario at the Airfarm, we're going to try it in a closer environment at PBC and see how it goes. Here's how it works:
There are three roughly equal teams; Alpha (green), Bravo (tan/brown), and Charlie (balancers like black, ACU, civies, etc.). There are TWO respawns that are roughly equidistant from "the hill" (the point everyone is trying to control). One team begins at the 'hill', this team has NO respawn. The other two teams begin one each at the two respawns, respectively. All three factions attempt to take control of the 'hill' by killing everyone else there and then maintaining their position there for as long as possible by defending it. The defending team CAN'T hold it forever because they only have two medic heals each and nowhere to respawn (when one of them runs out of heals, they stand off to the side and observe until their team is overrun). Whenever a different faction takes control of the 'hill', the faction that previously held it then gets the respawn of the faction that just took the 'hill', and around and around it goes. What's the objective? To hold the 'hill' longer than the other two factions cumulatively. It's important that we have players bring a change of fatigues in case the numbers are not balanced so some people can change.
Rules:
-Heal by tying bandage (provided) around upper arm, max two consecutive heals, all friendlies are medics
-Deadrags required to play (Available for $1 at game)
-Radios are recommended
-Stay hydrated!
-I highly recommend bringing a sidearm with no MED so you can clear fortifications
-AOSC games always go on as planned, no cancellations for weather
Important Reminders:
-You need to be IN LINE for Chrono and Registration BEFORE 0900. That means you need to show up at 0800, or 0830 at the very latest.
-SC Airsoft Supply will be vending with most everything you need in stock on sight.
Mini Op: King of the Hills II @ PBC on 08/22/2015
Re: Mini Op: King of the Hills II @ PBC on 08/22/2015
Faction leaders are as follows:
Alpha:
CO: Cole Matteson
XO: Alex Fulbright (Muffin Man)
Bravo:
CO: Jay Roach
XO: William Andrew Henley (Uboat)
Charlie:
CO: Kory Escue (Star_Folder)
XO: Kyle Esquivel
Alpha:
CO: Cole Matteson
Bravo:
CO: Jay Roach
Charlie:
XO: Kyle Esquivel
