Crisis in Dunundistan V - SQA 3/18/17
Information about past games.
Locked
Post by Dominum » Tue Feb 14, 2017 4:20 pm
Crisis in Dunundistan V @ SQA 3/18/17
Field Info:
SQA
1205 Founders Road, Lexington, SC 29073
SQA, 1205 Founders Road, Lexington, SC 29073
Portajohn on site; debit and credit cards accepted; field rental guns $20-$30 plus equal deposit; field sells: snacks, drinks, BBs, guns (both new and used), green gas, and much, much more; potable water provided to fill containers
Date:
Saturday, March 18th, 2017
Itinerary:
0800: Registration and Chrono Open (Field fee is $20 [$5 Military Discount with ID])
0930: Safety Briefing begins
1000: Game Start
1300: Lunch Break
1415: Game Resumes
1730: Game End
Scenario:
Fight to establish order in the small war-torn central Asian nation of Dunundistan. After years of turmoil, only an all-out victory for one faction or another can finally bring stability to its people.
Bravo: Independent Dunundistani Rebels
CO: Christopher Deuce Browder
XO: Tom Payne
Alpha: Pro Dunundistani Government Forces
CO: Adam Bennett
XO: Travis Collins
Each faction will have at least one permanent respawn, with capturable respawns available as well. There are essentially two portions of the objective structure: Faction objectives will be issued to your CO and will normally focus on the control of territory; Throughout the game, special missions will be assigned directly to squads by the Admin and will consist of whatever parameters are set in the mission brief.
Rules:
-Medic bandages provided, max two consecutive heals, all friendlies are medics
-Deadrags required
-Bring a radio or you won't know what is going on
-I highly recommend bringing a sidearm with no MED so you can clear buildings
-If you show up after we have begun play, check in at the registration desk. It is NOT OK for you to take the field without having registered and chronographed first.
Locked
