King of the Hills @ Blue Hole 12/02/2017
Information about past games.
Locked
Post by Dominum » Mon Nov 13, 2017 9:06 am
A unique three faction scenario. Join us for a great day of airsoft!
Directions can be found here
Or use 949 Richardsons Lake Rd Warrenville, SC 29851
Date:
Saturday, December 2nd
Price:
$20
Itinerary:
0800: Registration and Chrono open
0930 Safety Briefing begins
1000 Game start
1330 Lunch Break
1430 Game Resumes
1730 Game Ends
Scenario:
There are three roughly equal teams; Alpha (green), Bravo (tan/brown), and Charlie (balancers like black, ACU, civies, etc.). There are TWO respawns that are roughly equidistant from "the hill" (the point everyone is trying to control). One team begins at the 'hill', this team has NO respawn. The other two teams begin one each at the two respawns, respectively. All three factions attempt to take control of the 'hill' by killing everyone else there and then maintaining their position there for as long as possible by defending it. The defending team CAN'T hold it forever because they only have two medic heals each and nowhere to respawn (when one of them runs out of heals, they stand off to the side and observe until their team is overrun). Whenever a different faction takes control of the 'hill', the faction that previously held it then gets the respawn of the faction that just took the 'hill', and around and around it goes. What's the objective? To hold the 'hill' longer than the other two factions cumulatively. It's important that we have players bring a change of fatigues in case the numbers are not balanced so some people can change.
Rules:
-All friendlies are medics
Important Reminders:
-SC Airsoft Supply will be vending with most everything you need in stock on sight
Entrance to Blue Hole
Locked
