Paintball Central
318 Tucapau Road
Wellford, SC 29385
March 31st:
0800: Registration and Chrono open (Field fee is $15. Exact change is appreciated)
0915: Safety Briefing begins
0945: Game start
1230: Lunch Break
1700: Game Ends
PBC requires you to sign their waiver. This must be signed in lieu of the AOSC waiver. PBC waiver located here
If you've played airsoft for any length of time with the AOSC, you probably know Tweddle. He has been playing airsoft for longer than almost everyone reading this, and he's been in attendance as an objective at almost every major Op in the AOSC. Now this diminutive Prime Minister of Dunundistan has his own mini series.
This is part of a series of games at various fields, all involving either his capture, protection, or transportation. Some will have different twists with certain game mechanics to make it a little bit more interesting.
PBC has portajohns, a sink, and several large covered table areas. BRI.g your own water. SCAS will be vending Airsoft stuff.
-No medic heals inside buildings/mostly enclosed structures
-Thirty second heal, max two consecutive heals, all friendlies are medics
-Deadrags required
-All AOSC rules apply (standard game rules here: http://www.aosc.us/forums/viewtopic.php?f=8&t=5236 )
-Stay hydrated!
-Bring a sidearm with 0 MED to clear buildings (HIGHLY recommended)
Save Tweddle! @ PBC 03/31/2018 $15
