Support Gunners in Milsim
So, while I wait to get my first midcap mags for any upcoming milsim games, and a new box mag for my M249 just for general use, I got thinking; how common are support gunners in most milsim games? How much are they valued/targeted?
Re: Support Gunners in Milsim
Since MilSim is such a loosely applied term these days, that varies greatly depending on the game and rule set. It's not really answerable without more specifics.
They aren't terribly common. Generally they have a limit of 2 per squad, which usually makes 1 in every 5 players a support gunner. Not every squad has one, so that ratio is usually a little higher. In the milsims that limit riflemen to semi only, support gunners are very highly valued. Simply having the ability to run full auto is very strong when not many on the field have the option.
For games that allow full auto to riflemen, support gunners aren't as useful. A quick mag dump can do the same job, and you don't have to wait for a support gunner to show up to give cover. You still can't suppress people as well as you can with a support weapon, so they are still good for that.
Why do you think they aren't commion? Just because people get more rifles than support weapons?Star_folder wrote:They aren't terribly common. Generally they have a limit of 2 per squad, which usually makes 1 in every 5 players a support gunner. Not every squad has one, so that ratio is usually a little higher. In the milsims that limit riflemen to semi only, support gunners are very highly valued. Simply having the ability to run full auto is very strong when not many on the field have the option.
I'm referring to the games where you're only allowed a set number of midcaps and can't reload mags in the middle of a fight.Dominum wrote:Since MilSim is such a loosely applied term these days, that varies greatly depending on the game and rule set. It's not really answerable without more specifics.
Because there is a limit to 2 support weapons per squad, so 2 per 10, 1 per 5. At max capacity, this means slightly less than 20% of the weapons on the field are support weapons. However, I think the number is closer to 10-15% because many players would rather use a rifle rather than a support weapon. Support weapons are large, bulky, heavy. They slow you down and wear you out much more than an assault rifle does.Bulldog wrote:Why do you think they aren't commion? Just because people get more rifles than support weapons?Star_folder wrote:They aren't terribly common. Generally they have a limit of 2 per squad, which usually makes 1 in every 5 players a support gunner. Not every squad has one, so that ratio is usually a little higher. In the milsims that limit riflemen to semi only, support gunners are very highly valued. Simply having the ability to run full auto is very strong when not many on the field have the option.
- idiot88
............ plus you have to spend a lot of money on BB's!
