CAN SOMEONE HELP
Joshua
Re: CAN SOMEONE HELP
Post by Joshua » Wed Dec 29, 2010 9:39 pm
Jeremy314 wrote: Duuuuuude... DW.. dont' feed the troll man... just stop responding to him and eventually he'll go away....
He doesn't.  :D
IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE--IRENE
Echo1 Operator
Echo1 Rep
Echo1 Rep
Post by Echo1 Operator » Wed Dec 29, 2010 9:54 pm
You act like what I posted in this thread is false.  You really think TM has better customer service for US based customers than a US based company?  :roll:
TEH SCAA WILL RISE AGAIN
Esteban
Post by Esteban » Wed Dec 29, 2010 10:43 pm
airsoftsniper11 wrote: Redwolf and other overseas retailers aren't known for their awesome customer service.  I don't think Tokyo Marui even cares about US customers.  Echo1 leads the way in customer appreciation!
Echo 1 has safety in mind as all their guns shoot at a safe 420FPS.
calebbrady
Post by calebbrady » Wed Dec 29, 2010 10:48 pm
yo this has gone way of topic
I survived:
OP: Viper
Post by SteevoLS » Wed Dec 29, 2010 11:13 pm
True, but there really isn't much more advice (if any) to give. If none of those methods work, there must be some unholy epoxy holding the flashhider on.
Joshua
Post by Joshua » Wed Dec 29, 2010 11:15 pm
Run a flat head through the flashhiders vents on all sides, and just twist it. Best that can be given.
Echo1 Operator
Echo1 Rep
Echo1 Rep
Post by Echo1 Operator » Wed Dec 29, 2010 11:21 pm
Esteban wrote: Echo 1 has safety in mind as all their guns shoot at a safe 420FPS.
Echo1 does not claim to be perfect  :P
Be careful of wrenching on the flash hider before you have weakened the adhesive or you may accidentally damage the threading.
Veimos
Post by Veimos » Wed Dec 29, 2010 11:23 pm
On my Echo-1 there was an allen screw, AND a spring pin.  I'm not sure if there is a special tool for said pin.  Easiest thing to do, IF you're comfortable with power tools, would be to drill it out.  I had to use a pair of wire clippers and chewed threw it.  I then used a flat-head screwdriver and a small hammer to peel it off.
Hope that helps.
OP: Domino(RF)
OP: Strategies of War (RF)
OP: Attrition (AF) (Co)
theboss62
Post by theboss62 » Thu Dec 30, 2010 12:18 am
Rev wrote: If you heat the  whole gun then pick it up it will give you a great sensation.
haha i misread it but still is funny. Caleb did you get it off without trouble
Team AJAX
Arsenal- in the works
calebbrady
Post by calebbrady » Thu Dec 30, 2010 11:53 am
ok this is what im gonna do. get a bowl of boiled water but the flash hider in that for 5 minutes then blow dry it for 5 minutes get vise grips and use brute strength
I survived:
OP: Viper
Tzer1993
Post by Tzer1993 » Thu Dec 30, 2010 12:00 pm
Stick it in fire. That should heat it up! 8) <-That is not a for-real suggestion, by the way.
Post by Dominum » Fri Jan 07, 2011 4:53 pm
Buy a butane jet and heat it with that, seriously. It can melt zinc, so I'd say it can melt that adhesive.
Post by SteevoLS » Fri Jan 07, 2011 5:42 pm
... and pot metal.
Post by Dominum » Fri Jan 07, 2011 6:04 pm
We'll see... ;D
calebbrady
Post by calebbrady » Tue Jan 11, 2011 3:38 pm
ok i will try that, thanks everyone
I survived:
OP: Viper
