Echo 1 614
Echo 1 614
Does any one know any mods or upgrades i can do to my echo 1 614 to make it better, i already have a crane stock installed, any suggestions?
Re: Echo 1 614
Google would be a decent source of any and all upgrade options.
[img width=379 height=150]http://i241.photobucket.com/albums/ff20 ... 7Tac-1.jpg[/img]
Re: Echo 1 614
Thumper, what exactly do you want to make "better"? How old is this gun? E1's generally come with a great FPS out of the box.
for good starting points look into a tight bore barrel, new hop up bucking and nub, replace the 2pc hop up with a good 1 piece metal unit and you should have a pretty solid set up.
From there replacing the crappy wiring with some high quality stuff and using deans connectors. Replacing the wiring will require someone to open the box so at that point a thorough cleaning, proper lubing and a good shim job and you'll be set for a while. At that point run it until it breaks.
Re: Echo 1 614
What do you want to improve?
-Accuracy
-Rate of fire/trigger response
-Range
-Durability/longevity
If you want an accurate standard assault rifle type setup (340-400FPS) do what Severed said. If you want it to have a very high ROF or more range (DMR) then you may want to do a bit more. It's really up to your budget and style of play.
-Accuracy
-Range
Re: Echo 1 614
i would love to increase the rate of fire and accuracy
